richy
Flatheads forever....
Aug 13, 2004 22:10:50 GMT
Hello everyone
I've got a pretty tidy '82 Cortina Crusader with front footwells that seem to fill up with water as soon as the atmosphere becomes a bit damp.
I've had the metal underneath the heater matrix welded up, and I've fitted a new screen rubber, but the passenger footwell is still getting wet.
Any ideas please?
Aug 13, 2004 22:40:53 GMT
inner wing kick panels the inner wing rots and when driven in the wet the front wheels kick water up into the rear of the front wings
Aug 13, 2004 22:53:25 GMT
What about the inner scuttle panel up behind the dash? I'm not familiar with the 'tina's construction so I don't know if they rot there but some cars do.
Cortina Mark Five leaks!DarrenW
@darrenw
Club Retro Rides Member 74
Has it got a sunroof? If it's an aftermarket glass one it'll be pretty obvious if it leaks, if it's a factory steel one (I don't know if they had them) check the drain holes are clear. Open the roof and poke some stout wire down the holes to clear any blockages. Failing that, is the plastic membrane behind the door trim panel intact? If it's been hacked about to fit speakers/access the window mechanism it could be letting water in...
Aug 14, 2004 11:52:46 GMT
It could even be coming in the doors. Are the rubbers, and the panel gaps alright?
"He's not the messiah, he's a very naughty boy!"
richy
Aug 14, 2004 18:11:12 GMT
Guys: Thanks very much for all your suggestions! I know what I'll be up to over the next couple of days...
Aug 14, 2004 19:31:51 GMT
It ain't seeping in through the gap where the rear top of the wings meets the scuttle panel??
richy
Aug 14, 2004 19:46:09 GMT
Good point! Will get on the case tomorrow....
