I was daydreaming at work the other day about this. You could buy a snotter Rover Metro/100 and this.. With a bit of ingenuity and thriftiness you could have a dangerously quick and cool little hatch for £800 or so.. A perfect sleeper. Free bump because that's all I can afford.
gazwad
I have a vvc in my mini. Even standard they are stupidly fast, mine is tuned to about 180 bhp with just a little head work, piper ex cam, air filter and exhaust. All on the standard ecu. The wiring is simpler than it looks and only needs half a dozen wires splicing into your original loom.
Any dimensions you can get would be helpful, length/width/height I suppose are the main ones. What car is it out of, so I can look for tuning bits! :)l Hi Phil, I'll get what dimesnions I can today and report back. As said in the original post, the engine is from a Rover Coupe (1998 200 Coupe) but the engine is essentially the same as all the other VVC's The 145bhp engine can be taken to 160/165bhp quite easily with the 160 throttle body (usually around £40 on eBay), a 160 manifold (£20-£30) and induction (enclosed). This is backed up with the following response I found to someone looking to up the power of their 145bhp VVC: "An enclosed induction kit, 52mm Throttle body and manifold/sports cat/silencer combo will easily see 160BHP, but more importantly give a healthy increase in torque too."Don't forget that you don't have to run a cat which will help increase the BHP compared to the stock figure. To get any more you'll be into some headwork (port/polish) or different cams, but as Gazwad says, this will get you nearer 180bhp. Personally, it seems dead cheap and easy to get to the 160/165 area but gets progressively more expensive after that if you want to squeeze more out. Food for thought.
Dimensions for the engine are as follows:
Overall height (bottom of sump to top of cam cover): 640mm Overall width (bellhousing to end of pulleys): 510mm Overall depth (edge of manifold to edge of manifold): 540mm
They are as accurate as I can get give or take a few mm.
Hope that helps? It's quite a compact engine overall - certainly small enough to fit in a Metro or a Mini, so I can't see it being a massive problem fitting into an MGB.
Cheers for now,
Bruce.
What ECU is it? MEMS5 something or other? Stick it on Metro Power.
What ECU is it? MEMS5 something or other? Stick it on Metro Power. Thanks Dude, I'll have a look on there but have never been keen signing up to a forum just to sell something, always strikes me as bad etiquette and a lot of forums don't like it. I'll take a looksy though ;D As for the ECU, it's whatever the stock management is. MEMS stikes a bell, but as to what version/type I have no idea. I'll take a look at the casing and note the details down when I'm at the unit on Friday.
I put it up for you, linking back here! Thanks David, that's really kind of you. Beer owed if the set-up sells through Metro Power ;D
Jul 12, 2011 10:29:33 GMT
Anyone? Anyone?
Jul 12, 2011 13:15:37 GMT
** Provisionally SOLD **
