Jun 23, 2011 20:08:03 GMT
hi all, will hopefully be fitting a straight six bmw engine int my p4 rover soon, any advice on wiring it up? what will i need like ecu etc, looked at 2 engines recently,one was v-belt in a 1990 e30,1 was a flat belt in a 96 e36, which would be best/easiest? any help/tips and advice will be handy cheers paul
loving the dub
barty
Jun 23, 2011 20:10:34 GMT
you will need as much wireing as you can get from the donor car along with the ecu, relays pumps and well everything don't throw anything away till your done, Good luck
Jun 23, 2011 20:17:11 GMT
cheers barty ;D
loving the dub
Jun 23, 2011 20:31:20 GMT
One word -megasquirt
Or is that two?
Koos
hi all, will hopefully be fitting a straight six bmw engine int my p4 rover soon, any advice on wiring it up? what will I need like ecu etc, looked at 2 engines recently,one was v-belt in a 1990 e30,1 was a flat belt in a 96 e36, which would be best/easiest? any help/tips and advice will be handy cheers paul What belt were you looking at? E36 6-pots are chain driven. BMW engines come with an easily unplugged loom, which should contain your ECUs and pretty much all the engine wiring. look up X20 connector for info. The later engine (M50) will be a bit heavier, more powerful, more complicated, more reliable. Earlier engine (M20) will be the opposite of that.
was looking at fan belts lol
loving the dub
rob0r
East of England
Club RR Member Number: 104
bmw engine queryrob0r
@rob0r
Club Retro Rides Member 104
E30 6 cylinder "M20" engines are single cam and therefore less wide in the head area, they also sit more vertically than the E36 engines. 2.5L we are talking 170bhp. These are cambelt driven. They have front sumps.
E36 6 cylinder "M50" engines are dual cam and have much wider heads, they also lean to the drivers side compared to an M20. E36 have rear sumps, if you needed a front sump the E34 5 series M50s can donate a front sump. You can get tubular exhaust manifolds from an E36 328i. 2.5L are 190bhp.
Last Edit: Jun 24, 2011 8:43:05 GMT by rob0r
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
