;D really happy with the position, still needs to get plumbed in (job for later in the week) before i can start busting some sideways with it
street
6.2 ft/lbs of talk
Wahey thats good stuff! As long as its comfortable to use thats all that matters. Just reminded me wanted to have a look at Phoenix's hydraulic handbrake at CaRS
Last Edit: Jul 5, 2006 20:40:00 GMT by street
yeh i think its in the right spot. well, the only experience so far ive got of using it is sitting in the car (still on the ramp) making engine noises and pretending to hand brake it LOL
Nathan
Club RR Member Number: 1
Hydraulic Handbrake finally fittedNathan
@bgtmidget7476
Club Retro Rides Member 1
Some one told me that these are MOT failure is this right?
suppose it ok in a track car.
cool all the sam e
Last Edit: Jul 5, 2006 21:55:18 GMT by Nathan
Hydraulic handbrakes are not illegal. But you do need to have a seperate braking system for the main handbrake. So you have two options either you keep the cable handbrake as I and also I presume Gofasterpinch will do or you have to have a completely seperate hydraulic system including a seperate caliper. This way isnt as common any more but you used to see a lot of mk2 escorts like this for rallying after converting to discs before the popularity of the sierra rear caliper
mine is inline with the rear brakes. i cant use discs on the back without making it massively overbraked and having to use a bias box.
aslong as there is a cable system still attached then this is still an MOT pass. alot of the escort boys are using XR3i front calipers on the back, which means they need to fit a "spot" caliper or modify the XR3i caliper to run a cable aswell
