A while back on here somebody posted a thread with loads of facts about Top fuel dragsters. Loads of stuff about how much power they have etc etc.
Cant find the thread so could who ever did it please repost if for me! Cheers.
BS Nymph Singer Chamois Coupe Series 3 Landy
Did you know...
… that the nitromethane-powered engines of NHRA Top Fuel dragsters and Funny Cars produce approximately 7,000 horsepower, about 37 times that of the average street car?
… that one cylinder of the eight cylinders of a Top Fuel dragster or a Funny Car produces 750 horsepower, equaling the entire horsepower output of a NASCAR engine?
… that the gasoline-powered engines of NHRA Pro Stock cars produce about 1,200 horsepower, about eight times that of the average street car?
… that an NHRA Top Fuel dragster accelerates from 0 to 100 mph in less than .8-second, almost 11 seconds quicker than it takes a production Porsche 911 Turbo to reach the same speed?
… that an NHRA Top Fuel dragster leaves the starting line with a force nearly five times that of gravity, the same force of the space shuttle when it leaves the launching pad at Cape Canaveral?
… that an NHRA Funny Car is slowed by a reverse force more than seven times that of gravity when both parachutes deploy simultaneously?
… that NHRA Top Fuel dragsters and Funny Cars consume between four and five gallons of fuel during a quarter-mile run, which is equivalent to between 16 and 20 gallons per mile?
… that NHRA Top Fuel dragsters and Funny Cars use between 10 and 12 gallons of fuel for a complete pass, including the burnout, backup to the starting line, and quarter-mile run?
… that NHRA Top Fuel dragsters and Funny Cars travel the length of more than four football fields in less than five seconds?
… that NHRA Top Fuel dragsters can exceed 280 mph in just 660 feet?
… that from a standing start, NHRA Top Fuel dragsters accelerate faster than a jumbo jet, a fighter jet, and a Formula One race car?
… that a fuel pump for an NHRA Top Fuel dragster and Funny Car delivers 65 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time?
… that the fuel-line pressure for NHRA Top Fuel dragsters and Funny Cars is between 400 and 500 pounds, about 20 times greater than the pressure on passenger-car fuel pumps?
… that depending on size and angle, the large rear wing on an NHRA Top Fuel dragster develops between 4,000 and 8,000 pounds of downforce?
… that the 17-inch rear tires used on NHRA Top Fuel dragsters and Funny Cars wear out after four to six runs, or about two miles? Some brands of passenger-car tires are guaranteed for 80,000 miles.
… that it takes just 15/100ths of a second for all 7,000 horsepower of an NHRA Top Fuel dragster engine to reach the rear wheels?
… that it's desirable for an NHRA Top Fuel dragster to race with its front wheels inches off the ground for about the first 200 feet of the run? This ensures proper weight transfer to the rear wheels, a crucial part of a good launch and quick run.
… that the nitromethane used to power the engines of NHRA Top Fuel dragsters and Funny Cars costs about $16 per gallon?
Dig it up, slam it and drive it.
there are loads around the net check the santa pod website and also the nhra website
nice one larry!
this is what santa pod gave me, pretty much the same thing
"The nitromethane-powered engines of Top Fuel Dragsters and Funny Cars produce more than 5,500 horsepower, about 40 times that of an average street car."
"A Top Fuel Dragster accelerates from 0 - 100mph in about 0.9 seconds, almost 11 seconds quicker than it takes a production Porsche 911 turbo to reach the same speed."
"A Top Fuel Dragster leaves the starting line with a force nearly five times that of gravity, the same force of the space shuttle when it leaves the launching pad of cape canaveral."
"The dual carburetors on a pro stock car gulp more air per minute than is needed to inflate the goodyear blimp."
"Top Fuel Dragsters and Funny Cars consume between four to five gallons of fuel during a quarter-mile run, which is the equivalent to between 16 to 20 gallons per mile."
"Top Fuel Dragsters and Funny Cars travel the length of more than four football fields in less than five seconds."
"From a standing start, Top Fuel Dragsters accelerate faster than a jumbo jet, a fighter jet and a formula one race car"
"A fuel pump for an average Top Fuel Dragster and Funny Car delivers 58 to 60 gallons of fuel per minute, equivalent to eight bathroom showers running at the same time."
"The 17 inch rear tyres used on Top Fuel Dragsters and Funny Cars wear out after 4 to 6 runs, or slightly more than a mile. Some brands of passenger-car tyres are guaranteed for 80,000 miles." "The rear tyres used on Top Fuel Dragsters and Funny Cars reach 250 degrees fahrenheit during a quarter-mile run."
There is also one that has a statement like "The fuel air mixture in a top fuel dragster becomes so compressed it almost turns solid" .. or something like that
* One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona.
* Under full throttle, a dragster engine consumes 1 1/2 gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747 but with 4 times the energy volume.
* The supercharger takes more power to drive than a stock hemi makes.
* Even with nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition. Cylinders run on the verge of hydraulic lock.
* Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitromethane measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression-plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting off its fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow cylinder heads off the block in pieces or blow the block in half.
* Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the track) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
* To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. But in reaching 200 mph well before 1/2 track, launch acceleration is closer to 8G's.
* If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
* Dragsters reach over 300 miles per hour before you have read this sentence.
I gotta say though...
This has to be one of the most awesome videos I've seen in a long time.
Its 1000FPS footage of drag race cars..Really shows the forces at work required to power one.
AWESOME!
Cheers guys.
Nick
* * If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second. . This is one that boggles me, how the curse word do the top teams afford it?
this weeks car count "5"
* * If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second. . This is one that boggles me, how the flip do the top teams afford it? quite simple - sponsorship!
Nick
well yeh i figured but jesus thats some serious money got to be spent right there.
teams look for £200k upwards to compete in the european top fuel series.
serious money indeed - but to a company turning over millions is not such a big spend.
