My friend has asked me to offer his much loved Polo 6N for sale for him!
The car is a 1.9D CL (Non turbo with the AEF engine), I think there is 138000 miles on it but does have issues so will need to be towed away!
To start with I will list the good bits first
It's all in one piece
There's 1/4 tank of Diesel in it
Taxed till 31/07/2011
M.O.T till December 2011
Has 4 Good Tyre's
Has just had a new Aux drive belt fitted (which was a horrid job)
Had BOTH rear wheel bearings last year
Had a new diesel filter last year and hasn't done many miles since
No advisories on last 2 M.O.T's
Doesn't smoke when running
Now the bad bits ...
Needs a heater matrix
The starter Motor earth cable has melted and it definitely needs a new starter motor
The engine turns over but you have to get someone to hold down the earth strap on the starter (while it tries to set fire to itself) but for some reason won't fire up!
We think it may need new front wheel bearings
The front wings are rusty on the edges and need replacing/repairing
Now I will get to the engine issue, I tried to get the engine running earlier today but had little success. The missing aux belt was replaced (the car hasn't been run for 4 weeks since the last one snapped and was recovered home), once the new belt was fitted and the battery was charged it started first turn of the key and sounded very healthy, After a minute of letting it run I pressed the accelerator and as I did it immediately stopped running, No drama, no noises, it just stopped... since then all it will do is turn over constantly and not fire up! Diesel is getting through and there seems to be good compression but no life!
We can only think that the timing belt has slipped a tooth or the diesel pump timing has slipped off!
This is the reason my friend is selling the car as neither of us know diesel engines very well, up to now the car has been extremely reliable and never really had much in the way of mechanical problems!
I'm not sure if it's a 1996 or a 1997 but it's on a P registration and all the paperwork is present .. V5, MOT etc
The car has to be moved by Tuesday as my friend is going over to Spain for a holiday and doesn't want it to just be sat there!!!
He wants £200 NO OFFERS for it and considering the tax that's left on there and the length of the MOT I think this is fair!
PM ME IF YOUR INTERESTED AND LEAVE A CONTACT NUMBER I WILL RING YOU BACK!! THE CAR IS IN CHESTERFIELD, DERBYSHIRE
Has 4 Good Tyre's
