Muppet
Jun 27, 2006 11:38:10 GMT
my mk1 golf gti's been booked into jabba sport again ;D
anyone wanna guess how much it'll run after chip and pully? its got pg engine and 02a cable box (running hydralic clutch ) stage 4 jabba g-lader pro alloy front mount cooler bahn brenna charger outlet port supersprint 4-2-1 manifold powerflow stainless (and offensively loud ) exhaust jabba induction kit +air ram oh and a lightened flywheel! goes in july 4 th weekend before the festival so i can get some serious track time ;D
Jun 27, 2006 11:45:33 GMT
Just a touch over 200bhp I reckon on Jabba's Rollers with that spec - virtually identical to the set-up on my mates Corrado
BTW; PG engine is the G60 unit I presume?
Jun 27, 2006 11:49:34 GMT
I havent got the foggiest but it sounds like some serious mods. Is this 'Jabba', the place where that polovixen with the polo (with Capri rims on) goes?
Jun 27, 2006 12:30:29 GMT
Less than from a 440 mopar with a six pack?
Jun 27, 2006 12:37:29 GMT
Less than from a 440 mopar with a six pack? Less weight too ... In the mean time Mr.MuppetGTi I say this to you .... Hey man I know you got this thing out a comic book. I saw the add, two-ninety-five, it's right next to the sea monkeys.
Jun 27, 2006 16:14:14 GMT
180-200 ish
Muppet
Jun 27, 2006 16:32:30 GMT
hello derbydan pg is the engine code for the g60 yes , just trying to blind peaps with technical spiel ,you say your mate has nearly identical spec is there any differeance red tops bocsh injectors ? etc etc if it pushes 200 i'll be grinning for weeks!!!!!
jabba is jabbasport in crowthorp , near peteboghorror , can't fault them really nice guy's who will help if you have a problem , got the wiring diagram from them to adjust the corrado loom into the mk1 plus lots of other help (also 20v stuff but thats too new for me)
***edit*** eak for got to add this golf g60 and vag based 1.8t specialists
Last Edit: Jun 27, 2006 16:34:08 GMT by Muppet
SteB
Jun 27, 2006 17:40:39 GMT
200 sounds about ballpark for a modified G60, but it depends heavily on the size of the pulley (I'm assuming a 68mm, still on serpentine belts?) and also on the chip - there are alternatives to Jabba stuff, such as SNS which are getting used by a lot of people on dubforce.net
Muppet
Jun 27, 2006 19:01:13 GMT
yup ! will go for the 68 as a 65 seem's a bit extreme and i don't want a g-lader jig-saw puzzle, could go for another chip and pully ,but jabba sport is hour and a half down the road ,whereas g-werks is 5+hours away is there much benifit in a toothed belt?,as i'm running serpentine belt still , want one of thease though just funds wont strech that far
SteB
Jun 27, 2006 22:02:57 GMT
As for the belt size, a mk1 golf G60 cant possibly be a daily driver, can it?!? If its a toy, maximum 65mm and chip to match
Toothed belt drives completely eliminate belt slip allowing you to achieve higher boost at the top end, and whine a lot, which sounds really cool!
Heard mixed things about BBM setups, especially chargers destroying themselves when theyve shifted by a tiny amount on the mountings
Muppet
Jun 28, 2006 11:25:20 GMT
Use it every day i'd have to be totally mad for that ;D, the engine is near on solid mounted in the car , the exhaust is OFFENSIVLY loud ,in fact its so noisy on the 3 hour trip to gti international the passangers i took wore ear plugs ! yes it's the toy (got mk4 passat td est to do the 60 mile round trip for work) with the 65 mm pully , it'll be producing more boost lower down increasing the tourqe , any gain in power top end ? or will it be compromised 'cos max boost is achieved lower down ? don't know the pro's and cons of the pully sizes so if you can enlighten me that'll be great (oh part from the obvious that the service intervals are dramatically reduced ) g60 16v using the g-lader would have been nice but i've been F****D over by my boss again , any chance of getting a big bonus or big pay are now out the window hello cheap ass bonus and 2.5% inflation increase ,bye bye pay rise
