Having a clearout so have some bits for sale, can arrange postage at cost on all bits.
one way air valve for servo, brand new £8:
56mm throttle body for rover k series, ready for the correct TPS, £20:
Coilover springs, never used on the road, came with my GAZ coilovers for standard mini suspension £20:
Speedwell gearknob £10:
Aluminium wheel spacers 1" £10
Remote servo, i havent tested it but it looks new 1.5:1 ratio £50:
Fuel regulator £5
pair of downton style mirrors, generally good - slight rusting on bottom bit, may polish out £10:
MPI mini/MGF leather steering wheel, good condition, very little wear £10:
Pair of spot/driving lamps, untested. good condition some rust on mounting brackets £30:
Lucas spot light, untested, ok condition £10:
Polished cam cover- K series 16v (not vvc), could do with a little more polishing £30:
chrome gear knob, unused, flat on top for a badge £5
Stainless overbraid kit, unopened £20
Mitsubishi steering wheel boss for sparco/nardi/momo fitting + adaptor for mountney type fitting. fits delica/shogun/paj/fto maybe some others? £10:
Pair of crome bezels and knob covers for mini air vents, never used £8
Astrali wooden steering wheel, excellent condition £50:
Sportspack arches, genuine used rears and new ABS smooth fiberglass fronts, good condition £40
13" crome beauty rings(set of 4), fit most steel wheels, new never fitted £25
10" crome beauty rings (set of 4) fit mini 10" wheels, light scratches from storage, £20
MGZT diesel clocks, silver faces - maybe make custom gauges? £15
Fuel regulator £5
