1992 (J) 1600cc Mk2 Golf Ryder, 3 door in classic red
MOT until End of April 2012.
No tax, currently sorn.
124k, Documented by main dealer service history until 2001 (hand written entries and receipts there after) and all MOT's from 2001 until present.
4 Previous Owners, all based within 20 miles of Norwich.
Loads of History including original service book, owners manual and wallet.
The original supplying dealer plates are still fitted.
Factory Sunroof
Weber carb conversion
40mm lowering springs and new shocks fitted within the last 2 years
Cat 2 immobiliser with certificate
Lots of money spent recently including new windscreen, full service and cambelt, new front discs and pads, rear brakes checked, new hoses and pipes where necessary, brake fluid changed and coolant changed.
Body work is very good with the only rust being very small minor spots. There is no rot at all around the windscreen, filler cap, rear valance, front chassis legs, battery tray etc. The only let down is some minor dents to passengers side door and one in the rear quarter, but they're not that noticable.
The engine starts on the button and runs sweetly, the gearbox seems tight and there's no 2nd gear crunch even when cold. There are no worrying knocks or rattles when driving.
The interior as you can see from the pictures is very good, the drivers seat has slight wear (no holes though) but is still very good given the age of the car. If I was to be picky there are a couple of small splits in the top of the rear seat back caused by sun bleaching. The parcel shelf is good and un-cut but lacks straps and one of the clips on the side supports has snapped.
Here's some pics
Bad bits close up
Winscreen surround, pics taken when windscreen replaced
Price is £1195 o.v.n.o
Located near Norwich.
Factory Sunroof
Here's some pics
Bad bits close up
