Jun 22, 2006 21:58:29 GMT
(Fuggin weather, all exposed METAL! and left over untouchable rust patches and it wont stop raining!) Anyway, I intend to jenolite and rub away or cut down the non structural rust in the b pillar nook! then hammerite that and anything else exposed i can get to, then i wanna blast in the panels and through the skirt holes in the sills with some waxoyl style ectoplasm like a ghostbuster to warn off these ghoolish pesky brown flakes! So whats the best stuff to get? i have only glaced at it on shop shelves in passing, and wanna get the right rustbustin' plasm! any tips applying it? does it gust get splattered anywhere thats worried about? Cheers
bryn
I've only ever used Waxoyl, it was messy as hell (if Satan is untidy), but lasted a couple of winters. Aside from that I'm afraid I've never kept a motor long enough... Just avoid stuff like Tetrosyl the heavy duty stone chip, as in my experience it tends to dry and crack, trapping water underneath it, or err, on top of it if you see what I mean.
what i do is get yourself a pump spray bottle from the garden centre mix the wax oil at 60/40 with white spirit pump up the bottle to about 40 odd pumps then spray were you like no mess no fuss just go o'l wax oil protection andy PS some pref a stuff called dinitrol same sh1t diffrent day
Keep waxoyl well away from any areas you intend to paint otherwise you'll be in fisheye hell come top coat time.
Heat waxoyl up until very hot and it goes like water. It's easier to spray then. If you use it cold you can just whack it on with a underbody sealant gun but it puts it on a bit thick and tends to waste it. I have a special air powered sprayer thingy that does the job nice but can't remember where I got it. It looks a bit like a suction cup spray gun but with a long nossle on the front.
Nathan
Club RR Member Number: 1
Waxoyl treatment N stuff like thatNathan
@bgtmidget7476
Club Retro Rides Member 1
Jun 24, 2006 10:00:01 GMT
If its only small areas get the aerosol versions they will work out a bit cheaper. I have don't the GT every year before winter, but as its black when the sun gets on it in summer ou can see wax comming out the drainage holes lol
Jun 24, 2006 22:04:31 GMT
Big thanks all! A bunch of different serving suggestions, good stuff, I'll try one of em probs after CaRS, one more day to squeeze loads stuff in! Will probs take more bits off and spray/paint all the bits inside that i've just fixed, if i can get to em!
