racer86
'72 BMW 2002 / '72 Alpine A110 Gordini
Jun 21, 2006 21:24:34 GMT
Jun 21, 2006 21:36:37 GMT
try thinkauto (mocal UK) they do just about everything, all you really need to know is what oil filters will fit on your engine and you are sorted.
Jun 21, 2006 21:54:01 GMT
Demon Tweeks would probably have one if you were stuck. Could try cross referencing the oil filter at a motor factors and see what other cars have the same filter and then trying to source a sandwich plate for something more common
racer86
Jun 21, 2006 22:01:21 GMT
Cheers guys, ill have a look tomorrow. Project update coming soon !
Seth
Jun 21, 2006 22:11:20 GMT
I'd recommend Think Automotive too. They manufacture a lot of parts and really know their stuff. Been down there a couple of times to get odd old things sorted.
Rob
You know, for kids!
Jun 21, 2006 23:03:54 GMT
think auto from me too . . .
Jun 21, 2006 23:13:03 GMT
Mmmmmmmmmmmmmmmmmmmmmmmmmm Jaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaggggg
Stu
I got one for my Golf from Rallydesign, went for the mocal one with a 85 degree thermostat in it, helps the car warm up quicker as oil only flows through the cooler when it hits that temp or higher. www.rallydesign.co.uk/catalog/default.phpOn the site they only list the non-thermostat ones, but if you order one you can specify to get the thermostat one but it's about twice the price.
Jun 22, 2006 13:16:04 GMT
Think Automotive are Mocal You should get Trade as well Rob if you are a bit Creative when you speak to them They are very helpful..... if they don't have something I would be very very surprised www.thinkauto.com
Last Edit: Jun 22, 2006 13:18:10 GMT by CR500Dom
Jun 22, 2006 14:05:36 GMT
we can always get you one 30 ish
Jun 22, 2006 14:16:10 GMT
I can not add to what everyone has said, except that the 510 and watanabes combo in the picture above is pure s* 8-)x
bstardchild
Club RR Member Number: 71
Oil Cooler Sandwich Platebstardchild
@bstardchild
Club Retro Rides Member 71
Jun 22, 2006 14:18:18 GMT
Sorry to thread jack but it's along the same lines.............
Anyone know where you can buy a remote oil cooler thermostat unit?
Thermostat on the Opel straight six 24V engine is integral with the timing cover
Only one temperature stat is available 107 Deg C and IMHO and as a result of recent engine failures that is way too high!
Temporary cure has been to remove the stat and be very carefull when the engine is cold but it takes far longer to warm up as a result and I'd like to put some sort of temperature control in the circuit if I can....
PS to keep the thread slightly on track - I have a Monza sandwich plate - if thats the right size for what you need Racer86 - screws onto the filter mount and then the filter screws onto that - thermostat controled and with an in and out pipe mounts.
I gues you just need to compare oil filter thread and dimensions
Seth
Jun 22, 2006 15:28:55 GMT
Bstard, try Think Auto
racer86
Jun 22, 2006 16:38:36 GMT
cheers guys, i ordered one this morning, wish id had the one off you now bstardchild probably would fit. Oh well!
Jun 22, 2006 18:11:39 GMT
if you wont mind me asking...how much was it?
racer86
Jun 22, 2006 18:36:40 GMT
£28 for one with a built in thermostat from rally design ;D
