street
6.2 ft/lbs of talk
Jun 19, 2006 11:14:28 GMT
With the Escort almost ready for its MOT (1st one in 5 years! ) i'm currently just checking everything over as i need it to pass first time with CaRS bieng just around the corner So, a question: The rear springs, when the car is jacked up, come out of the spring cups because they are so short...... is this an MOT faliure?? A pic to make the thread mildly interesting Thanks RR'ers
Last Edit: Jun 19, 2006 11:23:48 GMT by street
Mr K
Jun 19, 2006 11:17:07 GMT
So, a question: The rear springs, when the car is jacked up, come out of the spring cups because they are so short...... is this an MOT faliure?? yup. that sure is. my mates mr2 mk1 failed on that.... to get it through we welded tabs onto the spring cup so the spring cant fall out. otherwise you could go over a hump back bridge and when the load comes off the back out they fall.... looks good though!!
Jun 19, 2006 11:21:35 GMT
cable ties FTW Fabricate something to ensure they don't fall out the cup, as that is an MOT fail.
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
street
6.2 ft/lbs of talk
Jun 19, 2006 11:25:33 GMT
Right will do, thanks for that fellas!
Jun 20, 2006 12:49:07 GMT
Cable ties won't be strong enough. A piece of cambelt bolted to the top and bottom cup which is fully extended just before pop-out point should do it.
Last Edit: Jun 20, 2006 12:49:48 GMT by rmad
Jun 20, 2006 14:11:09 GMT
Agree with Si. We always used to keep a bunch of old cambelts in stock for such activities. Just remember to fold each end of the belt over and but each bolt through the two bits so it doesn't rip.
There is nothing more expensive than a cheap Mercedes
Jun 20, 2006 14:23:03 GMT
Cable ties won't be strong enough. A piece of cambelt bolted to the top and bottom cup which is fully extended just before pop-out point should do it. Which reminds me,.. I need to get a Cambelt for this very porpoise...
Jun 20, 2006 17:04:14 GMT
i was very worried about this very occurance when the 230 went for mot. fortunately they never came out. phew.
Jun 20, 2006 18:48:39 GMT
Cable ties won't be strong enough. A piece of cambelt bolted to the top and bottom cup which is fully extended just before pop-out point should do it. best thing is seat belt webbing, a lot stronger than cambelts, just rivet it together and don't forget to melt the ends to stop it fraying
spacekadett
F*cking take that Hans Brrix!!
Jun 20, 2006 19:07:06 GMT
The MOT is (or was, it may have changed) a bit vague on this. Basically you have to jack the car so the suspension is on full drop, so lower springs are loose. BUT, if when you lower the car back down they locate correctly, that is a pass (but probably advise!) . It's only a fail if they fall out in the test. I am an MOT tester, although I don't do many, so if I get chance I'll check it in the book. Personally tho, I think they should really be strapped in
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Jun 20, 2006 19:13:21 GMT
don't worry about it street ive had some really low escorts and ive never had trouble on mot's aslong as they arn't rattling about and are held into the cups by the rubber
Jun 20, 2006 19:16:40 GMT
Landrover guys use leather straps as travel limiters for MOT purpose. So Image the seatbelt idea would work really well.
Jun 20, 2006 19:44:46 GMT
So Image the seatbelt idea would work really well. it does, seen it a hundred times. you could always remove the springs and run on the bumpstops, no springs to fall out then ;D ;D worryingly popular mod on viva front ends under "brit rods"
street
6.2 ft/lbs of talk
Jun 20, 2006 20:06:22 GMT
Well my approach was a bit heath robinson but should be ok: Drilled a hole through the boot floor, which goes through the spring cup, and ran a mountain bike brake cable through the hole to the lower arm, adjusted so its taught just before the spring are free Wish I would have spotted the later replys earlier, a cam/fan belt would have been a bit better, didn't think of that! Hey ho, all done now!
Last Edit: Jun 20, 2006 20:07:40 GMT by street
Jun 21, 2006 13:36:59 GMT
is your car ready for the road then shame I'm not going to cars i would of like to of seen it whats your engine spec at the moment then fella are you still running 40's
