Apr 18, 2011 19:51:30 GMT
...Actually its for a Wolseley 18/85, made by Girling. The part number is 64674336 Are there any out there?
I could also be interested in any other landcrab parts that may be knocking about!
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Apr 18, 2011 19:57:21 GMT
Hi, can you get a picture up of it?
I have 2 working spare girling slave cylinders from the same era, one off a dolomite, one off an 1800 marina? All BL, so may fit?
Tillio Race Prep and Spares Ltd
Oval racing Rollcage fabrication from £250.....Track car builds, engine conversions etc...
Apr 18, 2011 20:10:09 GMT
Ill have a go- from what i've read the 1800 crab only shares its slave cylinder with some type of Morgan.
Apr 18, 2011 20:21:37 GMT
![](http://i46.photobucket.com/albums/f121/lankytim/IMAG0280.jpg) Tadaa, pictured with 10p for comparison
Apr 18, 2011 22:06:04 GMT
have the following 1800 bits
clutch hose(x3) £1 each brake hose, £1 cv joint outer end (cup),£10 handbrake cables (x4 pieces), £10 the lot oil filter, £1 air filter (x7)£10 the lot frt wheel bearing (x3),£5 each water pump,£10 throttle cable.£1
or £50 the lot
theres more to life than mpg & to much power is just enough.
Apr 18, 2011 22:09:41 GMT
Ta, I don't think I need any of those bits ATM but i'll bear them in mind when I do!
Apr 19, 2011 21:12:48 GMT
Ive buggered the thread for the bleed nipple in the one in the pic, does anyone know if they can be refurbed?
