Jun 14, 2006 18:30:40 GMT
i got given a head for free today ;D
so it seams like an excuse for some porting action....but i havent a clue where to start. anyone got any tips/tricks or websites i can look at??
Jun 14, 2006 19:02:11 GMT
spacekadett
F*cking take that Hans Brrix!!
Jun 18, 2006 21:45:29 GMT
If your just starting playing with headwork, I'd start by just cleaning the ports up. The castings can be a bit rough, so just grind / sand them smooth. Vauxhall ones can also be a bit rough where they're machined to fit the valve seats, so give that a grind too. Certainly seems to have worked on the Kadett! Good luck!
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Jun 18, 2006 21:59:15 GMT
You need to build a flow bench from an old hoover, some MDF, some plastic tubing and a bottle of wine before you do anything.
Seriously though, unless you've got some way of measuring your results you could end up doing more harm that good, big ports don't mean big power.
slater
Club RR Member Number: 78
An Idiots Guide To Headworkslater
@slater
Club Retro Rides Member 78
Jun 18, 2006 22:06:08 GMT
Yeh you relly do need to know what your doing if you want to attualy change the shape of the port but you can get good gains by getting rid of the sharp edges and casting imperfections!
Jun 18, 2006 22:29:10 GMT
