I'm after a new car and whatever I get I get I want a checkered roof, I noticed most have a 4" square, can I get smaller ? also is can I get black and White checkered to do the roof, will it come in little squares or one big sheet,or how much would it cost for sumone else to do it
cheers tom
I did mine with paint, can do any size you want then
Go to a sign shop and buy a few metres of black vinyl (a lot of DIY stores sell Fablon which is also ideal, but probably won't last as long) Craft knife & ruler....cut cut cut, now you have lots of black squares whatever size you deem right for your car. Paint the roof white, let it dry, add black squares.....done. Or buy a few metres of white and do the same as with the black but it'll be a bit trickier to get tham all perfectly lined up. Maybe cover the roof with the white vinyl (a few seperate strips to cover the whole roof, a little bit of overlap won't notice) and then add the black. Draw/mask/mark a centreline through the middle (both ways) and work out carefully from there. DON'T start at an edge A few pounds costs, a few hours work and you're done.
I'd look in to borrowing or buying a guillotine if I had to cuts that many squares out
checkered roofDarrenW
@darrenw
Club Retro Rides Member 74
Go to a sign shop and buy a few metres of black vinyl (a lot of DIY stores sell Fablon which is also ideal, but probably won't last as long) I had Fablon on the roof of my old Corsa and it was fine after nearly three years I did the roof on my Kangoo with Fablon too, the current checks have been on for well over a year and they are the same as the day I put them on My Blue Renault Kangoo Van by retromotoring, on Flickr
Apr 10, 2011 17:46:34 GMT
This is my wife's car, it was a bit fidaly but worth the effort.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
Apr 10, 2011 18:59:50 GMT
cheers all will look about for vinyl
duncanmartin
Out of retro ownership
Club RR Member Number: 70
checkered roofduncanmartin
@duncanmartin
Club Retro Rides Member 70
Apr 10, 2011 19:04:18 GMT
I quite fancy doing that to my Dedra, but it's got a (dark) glass sunroof. What's the best way to deal with that without it looking rubbish? Excuse the poor quality pic: Cheers Duncan
bstardchild
Club RR Member Number: 71
checkered roofbstardchild
@bstardchild
Club Retro Rides Member 71
Apr 11, 2011 20:19:18 GMT
Sunroof didn't mater on a darker car
