Bet you were chuffed with the engine internals! The A6 is quite an old style grind by today's standards. If you ever rebuild it again think about replacing it with a Kent 244 or 254 depending how much lift your head can accomodate. The 244 will give you a bit more top end power but a lot more bottom end grunt. i bought another cam recently as it is not really suited to road/fast road use, got my self a kent KC3FY Application Power Band Cam Lift(mm) Valve Lift(mm) Duration Timing Full Lift VC (mm) LTDC Required Parts Sports 2500 - 7000 6.70 I 9.88 E 9.82 276 Deg 30/66 66/30 108 Deg I 0.30 E 0.36 I 2.16 mm CF6 / CF7 VS5 hopefully a bit more friendly for the road
Now that's nice. Spot of luck with the engine too! thanks, was a nice result, was told it was a hot engine but you have to take these things with a pinch of salt really
Bet you were chuffed with the engine internals! The A6 is quite an old style grind by today's standards. If you ever rebuild it again think about replacing it with a Kent 244 or 254 depending how much lift your head can accomodate. The 244 will give you a bit more top end power but a lot more bottom end grunt. I bought another cam recently as it is not really suited to road/fast road use, got my self a kent KC3FY Application Power Band Cam Lift(mm) Valve Lift(mm) Duration Timing Full Lift VC (mm) LTDC Required Parts Sports 2500 - 7000 6.70 I 9.88 E 9.82 276 Deg 30/66 66/30 108 Deg I 0.30 E 0.36 I 2.16 mm CF6 / CF7 VS5 hopefully a bit more friendly for the road Yeah that's much more like it for road use. The A6 profile hails from yonks back and was designed for short oval/hot rod racers with low gearing. The lack of low down torque and power combined with a 3:54 diff probably made it feel even longer geared than it really was. The new cam should improve things considerably.
May 14, 2012 10:02:37 GMT
you, you and you, Panic! - the rest of you, come with me!
Adz
May 14, 2012 19:44:09 GMT
brilliant project and a nice story to go with it
