hi all I have to sell my track day toy
it has mot till june 30th 2011. no tax
not been used on the track yet so all parts are brand new and never turned a wheel.
brand new parts fitted.
coilovers
drilled and groved discs
track rod ends
ball joints
steering wheel hub ( not fitted )
new plugs, leads and dizzy cap ( not fitted )
it has a s/steel back box ( not fitted )
carbon fiber cold air box with alloy tubing.
bad bits
it only has the 2 front seats
no door cards
I have made a start on cutting the dash in half to make a half dash and started to cut the iner metal from the passenger side front door
the drivers side door lock is not fitted but it is there just needs the right clip
good bits
most off the hard work has been done
lots off expensive parts fitted
mot till june 30th
cost me well over £1200 so far I will take £750 for it on standard 13"steel wheels
also it will need a small bit off welding on the sill for its next mot
the black alloys will not come with the car
its up for sale for one week and then I will be breaking it for parts
coilovers
track rod ends
ball joints
bad bits
no door cards
good bits
mot till june 30th
