ozzy
been after a puch for some time. I use to have them in my teens. I also have a 1968 runabout. but I want to have that for sunny days and shows. the puch will stay as it is but have a 70cc kit and sports pipe plus some other go faster bits to use around town got it off ebay for a very cheap price. it need a carb and exhaust and a rear light.
1985 GMC camper family wagon 1989 nissan sunny 1994 fiat cinq my boys car
I'm loving how popular these are becoming aha!
Not bad that one, not bad at all.
Russ
The puch army is getting bigger ;D
ozzy
put up on my facebook that I got a puch and now a mate off mine iss bidding on ebay for one. if he gets it I am going to send him here. so there will be one more soon
Pahaha, they're breeding.
CanMan
I don't understand these? They run on petrol but to save petrol you ride as your going down hill? Like a moped but you get rewared by pedaling :L
The pedals are to start it . You pull a starting lever to engage the clutch and pedal it until it fires up.
ozzy
picked it up today it had been left outside for some years and had a bag over the engine no plug it was ceased up and would not turn over so I pulled the head off and gave it a light tap and now it turns over. also I has a good spark now I have fitted a spark plug and I hve tested the horn and front light. the cluch works well but the lever on the bars for the brake and cluch lever has snaped on the brake side. so it looks like all it will need to get it on the road is a new brake lever, tail light, down pipe, carb, fuel tap and A flywheel cover. need help with the switch on the bars. its on the left hand side with a lever that can go back 1 notch and forward 2 notches a button on the top and a very small button at the back. I know the top button work the horn and the lever on the side works the lights. what does he small button a the bak do ? I have tryed to push it when I have been pedaling the engine over and it doe not do anything. I was thinking it was a kill switch but its still getting a good spark ?
Last Edit: Apr 6, 2011 0:06:18 GMT by ozzy
Yep its a kill switch.... depends what year engine you have. Some didnt have a cutout switch and you had to decompress them to stop (like mine) But I wired a simple cut out into it...
All it did was earth the LT side of the coil...
So if you run a wire from the condensor or points, Up to the pin that switch touches, It should kill the spark when pressed.
You might allready have the wiring in place for it though. How many wires do you have coming from the magneto? Mine had just yellow and a green/black wires.. (2 wires) and a white wire from the headlight switch to the rear light.
I added one red wire for the cutout. Using the standard connector block and connected it to the condensor .
Last Edit: Apr 6, 2011 7:39:38 GMT by retrowagen1234
ozzy
thanks I will have a look and see what wire I have
