Smiler
Dec 30, 2011 23:00:38 GMT
Liking lots!
I think a welded diff on one of these might be a bit much for the poor old void bushes so probably a smart move not to use it.
I really must get on with my old Corty. Take a look at my website, I've put up details of the vented front brakes upgrade on there that might be of interest.
Regards,
Smiler.
frankie28
Bring on the Cortina's
Dec 30, 2011 23:09:02 GMT
Good luck with it Dan, Hope you have tough fingers mate. You are going to need them bud! Would be good to see it yellow again! Must have some heavy paint on there, took me ages will 1200 and t-cut to try and get some shine from the black paint. even got my 10 year old grafting on it. Keep coming with the updates.
Frankie
Dec 30, 2011 23:36:49 GMT
No DA from Santa, the stingy git!To be honest I wasn't sure I wanted to use a DA anyway, as was worried it might take too much off, and go 'past' the yellow.Is quite tough going, but ill look like Mr Motivator soon(or one arm at least!). Ill have a look at your site Smiler, will be of interest.I'm really interested though in how to install a LSD. Cheers Frankie, fingers are tough, but my right hand looked like it'd been in the bath for hours by the time I'd finished. I did make more headway today, but didn't get a pic.Tommorow though.Hope your cars progressing too by the way.
Spent an hour or so at the unit today.De-painting progress!
frankie28
Is the paint still looking ok under that black so far then Dan?
Frankie
Is the paint still looking ok under that black so far then Dan? Frankie Yeah, its not looking so bad to be honest.A lot of the black just flakes off!Some T cutting etc, I recon it'll be good for a bit! ;D
Jan 13, 2012 13:12:54 GMT
any more updates on this ?
Feb 11, 2012 10:23:40 GMT
any more updates on this ? Sorry, been a bit slow of late, I'm in the last push of fixing my house.Then all attentions on this and the Granada. Update is that the hand sanding was working, but I keep getting thin bits through the paint.So you can see whats under the yellow.This means that that panel will need painting.Not a problem, but if I get a bit like that on every panel, its basically a full respray!So, Ive changed tack a bit, and decided to paint the whole lot.So Ive bought a compressor, and decided to bravely/stupidly take on the task myself.Someone on here(cant remember who I'm afraid)made a really good thread on doing this, which has helped.I'm thinking, it needs doing anyway, so I cant make it much worse right? Ill keep you posted.
frankie28
Feb 11, 2012 13:13:52 GMT
Need some piccies up Dan!! By the way, I noticed that someone was selling a headlining on buysellcortina for a mk5 saloon this morning.
Frankie
Feb 11, 2012 20:47:53 GMT
Need some piccies up Dan!! By the way, I noticed that someone was selling a headlining on buysellcortina for a mk5 saloon this morning. Frankie I know, I know!I'm being proper slack. Cheers for the headlining info, but Ive got one, just needs fitting.Got a bootlid too now.Desperate for a rear window louvre if you ever come accross one!Few and far between I know.Hope yours is progressing.
frankie28
Feb 11, 2012 22:09:50 GMT
Need some piccies up Dan!! By the way, I noticed that someone was selling a headlining on buysellcortina for a mk5 saloon this morning. Frankie I know, I know!I'm being proper slack. Cheers for the headlining info, but Ive got one, just needs fitting.Got a bootlid too now.Desperate for a rear window louvre if you ever come accross one!Few and far between I know.Hope yours is progressing. Yeah its coming along ok Dan, Slam panel welded in place, wingrail replaced, Upper front valance repaired, just needs some dressing and welding onto the car, bonnet found, got to do a patch on the drivers side wingrail, wing found, all dummied up and ready to go. Need to find a front bumper now. Good days work and she will be ready for painting. Then go through it and sort out the MOT as that runs out begining of march. Going to play with it this coming Friday (day off) and hopefully it will be sorted out. Will keep my eyes open, used to be several MK5's running round here with rear louvres a few years ago but they have all gone now.
Mar 28, 2012 21:47:12 GMT
So, not updated this for a bit, here's whats been happening. After making the decision to paint the whole car, I thought that to get around to doing it would take a while, and being a bit impatient to get it back out on the road(Brean Beach Party was my deadline), I decided to re paint the yellow bits I'd sanded back, and just get out and use it for a while.Then when I get a big enough gap inbetween shows etc, Ill go for the yellow! Before and after; The exhaust has really seen better days, with lots of holes.So I took it off, welded it, powder coated it, and put it back on for a temporary fix.To be honest, didn't work all that well!It was ok for a bit, then it got hit a few times on speedbumps etc, and is rubbish again!It rattles a LOT, and is leaking in a few places, so next week Its going in for a full stainless system! ;D I also had a problem whereby I'd get a huge vibration through the drivetrain.Not too bad at idle, but over 2500 rpm it was terrible!Couldn't see anything obviously wrong, so started worrying it was gearbox shot, or big end going? Turns out the gearbox crossmember rubber had collapsed/perished so much, that the smallest bit of gearbox, about a millimetre's worth, was touching the crossmember itself, causing the problem. So feeling pleased it was an easy fix, I ordered a new mount. Took the old one off tonight, and it just fell apart!Picture with the new part.Still, another problem sorted. MOT next month though! So we'll see how that goes.
mikeymk
'85 Polo Coupe S 1.6 16v
Mar 28, 2012 22:26:14 GMT
Not tempted to get it back to it's yellow glory?
After making the decision to paint the whole car, I thought that to get around to doing it would take a while, and being a bit impatient to get it back out on the road(Brean Beach Party was my deadline), I decided to re paint the yellow bits I'd sanded back, and just get out and use it for a while.Then when I get a big enough gap inbetween shows etc, Ill go for the yellow! cant you read properly mikeymk ? was in the post just above yours
if sparks don't fly you're ridin too high !
qwerty
Club RR Member Number: 52
1980 2.0 Cortinaqwerty
@qwerty
Club Retro Rides Member 52
Glad to see the old girl is still getting some love. Can't wait to see it once its yellow.
dapper
So there you go Dan, just in case you didn't get it, the consensus is go back to the Y E L L O W.
Enjoy the summer BACK IN BLACK though.
How low can you go?
Yep, Yellow is the way forward. I can't wait to get it back to Yellow too, it's gonna look sooo good.mellow, in Yellow. Untill I get the engine tuned of course! ;D
Granadaman72
I likes Granada's, Cortina's, Sierra's, Viva's, Marina's....................
Mar 29, 2012 18:17:44 GMT
Excellent stuff, its looking really good, cant beat a Tina .........well unless its a Granada ;D
Mar 29, 2012 20:58:47 GMT
Excellent stuff, its looking really good, cant beat a Tina .........well unless its a Granada ;D Thanks!The Granada's getting the treatment soon too, watch this space!Well, the Granada space anyway! ;D
Mar 29, 2012 21:03:09 GMT
Yay dan-cortina progress! Suffering at the hands of my shitroen buggerlingo van at the mo due to having a mojo eppy and selling my dodge and saving to move but my 2013 car will be a mk5 tina damm it! or an ital......
Last Edit: Mar 29, 2012 21:04:27 GMT by daveaspley
