Mar 27, 2011 10:49:02 GMT
Caddy has been making an increasingly loud and frequent noise I thought it was steering related as it seemed to do it only when you turned the wheel and not over speed humps or whatever but it does seem to do it when you bounce it. I've been under it this morning and checked for play in stuff, binding stuff, stuff which looked like it shold be lubed but wasnt't and nothing obvious amiss. All grease points look recently attended to. Nothing lose, broken, rough, loose, leaking. I originally had it down as a bush gone hard, tey squeak and creak, it sounded like a galleon on the high seas. Oddly enough it doesn't do it "from cold" the car has to have done a couple of miles. click for video and turn up ya speakers... Now I come to bounce it I'm pretty sure its a shocker thats had it. Thoughts?
Last Edit: Mar 27, 2011 10:49:29 GMT by akku
Mar 27, 2011 10:54:07 GMT
Does your car have a rubber bit at the top of the shocker as it could be that (same noise on the panda).
1993 Fiat Panda Selecta 2003 Vauxhall Combo 1.7DI van 2006 Mercedes Kompressor Evolution-S AMG SportCoupé
"You think you hate it now, wait til you drive it"
Mar 27, 2011 11:23:03 GMT
No idea what the noise is but if you try and get some nookie in the back we'll hear you a mile away ;D
Seth
Mar 27, 2011 12:03:15 GMT
No idea (other than what you've already considered) but that video needs a bo11ox-fuel-tank-video-esque soudntrack. Or maybe a quick blast of Fat Harry White at the end. Mmmmmmm, baby.
CIH
Mar 27, 2011 12:07:18 GMT
Does sound like a seized bush.
rld14
Mar 27, 2011 12:20:20 GMT
Sway bar bushings...
88 BMW E28 M5
62 Vauxhall Velox
60 Vauxhall Velox
60 Lincoln Premiere Coupe
60 Lincoln Continental Mark V Convertible
54 Ford Customline Fordor
32 Ford Roadster
Mar 27, 2011 12:51:36 GMT
Time for Mr Moog to save the day then. It's been a sway bar weekend. The whole bar came off the Chrysler yesterday!
10mpg
Club RR Member Number: 204
whats that noise?10mpg
@10mpg
Club Retro Rides Member 204
Mar 27, 2011 13:38:37 GMT
I'd put my money on a worn shocker...
had similar on various cars, usually yanks oddly enough...
Mar 27, 2011 13:59:54 GMT
My triumph does that occasionionally. Its very annoying
Mar 27, 2011 14:04:53 GMT
Shock seems most likely to me, too - the squeak sounds as though something's moving linearly for a fair distance, rather than rotating through a few degrees (bushes on suspension arms and sway bar).
Mar 27, 2011 15:39:51 GMT
It seems to bounces how it should.
Eh
With car stationary turn the wheel lock to lock it groans all the way.
I guess that wouldn't deflect the shocks that much, but would put sway bushes under tension?
Mar 27, 2011 15:43:59 GMT
Give each bush, bearing and mounting a skoosh with wd40, one at a time, bouncing it in between each dose until the noise disappears/changes tone. If that doesnt work, then look at the shocker.
Mar 27, 2011 15:45:35 GMT
True - I really don't know. Hope it's a fairly easy fix.
Mar 27, 2011 20:47:40 GMT
cheers, I'd heard the WD40 trick before and forgot it, I usually find my bushes split before they creak so I've never been in need of that trick!
Mar 27, 2011 23:49:35 GMT
Sounds mighty similar but not quite the same as a spring I had rubbing off the spring cup when the rubber protector wore through. Doesn't quite sound like metal on metal though, does sound more like a rubber squeak.
destroyed/disintegrated bump stop on shock damper?
destroyed/disintegrated rubber isolator - sits between shock top cap and suspension turret?
dry shock stanchion rubbing on seal?
no idea of the suspension design of the caddy but it sounds like rubber has gone dry and is rubbing on metal..just a thought.
Mar 28, 2011 11:51:05 GMT
OK, according to Rock Auto there are 2 sizes of front sway bar on this car, I have to measure it. Is this an excuse to get an upgraded one from ADDCO or PST? LOL.
