engine dimentions Deleted
@Deleted
Mar 25, 2011 21:04:54 GMT
trying tho decide what engine to put in the FB victor wagon . i would like a straight 6 of some sort though 4 or 5 cylinder engines will also be considered . i needs to have a rear drop sump and ideally originally rear wheel drive . if anybody has any suggestions and dimensions of what ever engines that would be great cheers heres a few i'd like to get the measurements of to get the ball rolling ![](http://www.okrealgood.com/volvo_powah13.jpg) ![](http://mkiiisupra.homeip.net/images/1jz/1jzgteb.jpg) ![](http://memimage.cardomain.com/ride_images/3/640/4441/26599720043_large.jpg)
kevfromwales
the conrod's REALLY out the block now!
Mar 25, 2011 21:14:05 GMT
no dimensions sorry mark, but I know the old street machine project cresta was powered by a nissan straight six? - rwd, manual or auto options, strong, reliable, sound nice - chevy stovebolt to *really* upset people ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Mar 25, 2011 21:44:42 GMT
I'm sure opel/irmscher did a 4.0 straight 6 as well. seen a couple for sale in opel flash (german magazine)
benzine
Club RR Member Number: 87
engine dimentions benzine
@benzine
Club Retro Rides Member 87
Mar 25, 2011 22:26:00 GMT
I can get you some dimensions for that Volvo 6 cylinder (that exact engine in the pic btw ![:D](//storage.proboards.com/forum/images/smiley/grin.png) ) i'll try and get some over the weekend
Last Edit: Mar 25, 2011 22:26:40 GMT by benzine
Mar 25, 2011 22:47:41 GMT
Why is there a lady in the volvo picture?
That volvo engine is the pic of the bunch posted, the others are iron block and old hat (no offence MrBstardchild).
And you get that lovely straight six howl too.
J
@Deleted
no dimensions sorry mark, but I know the old street machine project cresta was powered by a nissan straight six? - rwd, manual or auto options, strong, reliable, sound nice - chevy stovebolt to *really* upset people ![;)](//storage.proboards.com/forum/images/smiley/wink.png) yeah the old street machine cresta had an L28 in it nice engine but a bit bigger than i have space for the plan is to get it in without having to cut the bulk head as i want to retain the pop up vent and that nice little recess at the rear of the bay kinda make what ever goes in look a little more factory hence going for an in line engine rather than a V I can get you some dimensions for that Volvo 6 cylinder (that exact engine in the pic btw ![:D](//storage.proboards.com/forum/images/smiley/grin.png) ) i'll try and get some over the weekend that would be great if you could as thats my first choice of engine it will be mated to an auto box as well as it will be a cruiser I just want a really neat looking engine to go in what i'm hoping will be very nice smooth engine bay Why is there a lady in the volvo picture? That volvo engine is the pic of the bunch posted, the others are iron block and old hat (no offence MrBstardchild). And you get that lovely straight six howl too. J I can't see a lady in the pic the volvo lump is what I would like to get in there but will depend on cost though they seem to be fairly cheap for a whole car at the moment if the 6 turns out to be to long then I will consider the 5 cylinder version but that will mean having to source a box separately as the 850s are wrong wheel drive
Last Edit: Mar 26, 2011 7:49:08 GMT by Deleted
Mar 26, 2011 12:01:12 GMT
Weird, lady now gone, very strange!
benzine
@benzine
Mar 26, 2011 21:33:32 GMT
Got some rough dimensions just now in the garage. (all in mm)
Back of block to front of cam pulleys - 660 (add another 60mm for crank pulley) Top of cam cover to bottom of front part of sump (shallow end) - 530 Top of cam cover to bottom of oil filter - 600* Top of cam cover to bottom of deepest part of sump - 680 (mine has been chopped though, I think I took off a good inch) Width of engine - 280 (minus inlet plenum and exhaust)
I forgot to measure how far back the deep part of the sump begins, can do that if you want along with any specific measurements you're after.
* oil filter is at the front right corner of the engine when looking it at from the front of the car. On early engines it's vertical, on later engines it sticks out 90 degrees to the right. I used an early sump to clear a chassis rail.
Mar 26, 2011 23:19:16 GMT
Wth ref to this ![](http://memimage.cardomain.com/ride_images/3/640/4441/26599720043_large.jpg) Don't have any measurements i'm affraid but the c30se 24v engine from a carlton has a front drop sump as standard Its a big alloy affair that has braces at the rear that bolt to the gearbox aswell This is a side view (front at left) The middle was cut out for clearance when fitting it into a manta (about 1" cut from left side and sloping across top) ![](http://homepage.ntlworld.com/mantasport/mantasport/pics/shauns/c601otl%20(47).jpg) So that may not work for you.
@Deleted
Mar 26, 2011 23:28:22 GMT
Got some rough dimensions just now in the garage. (all in mm) Back of block to front of cam pulleys - 660 (add another 60mm for crank pulley) Top of cam cover to bottom of front part of sump (shallow end) - 530 Top of cam cover to bottom of oil filter - 600* Top of cam cover to bottom of deepest part of sump - 680 (mine has been chopped though, I think I took off a good inch) Width of engine - 280 (minus inlet plenum and exhaust) I forgot to measure how far back the deep part of the sump begins, can do that if you want along with any specific measurements you're after. * oil filter is at the front right corner of the engine when looking it at from the front of the car. On early engines it's vertical, on later engines it sticks out 90 degrees to the right. I used an early sump to clear a chassis rail. thats great stuff mate cheers for that. the volvo engine is actually a bit smaller than i had expected and may just work in there. i shall get the tape measure out in the morning and see just how much space i'm gonna have under the bonnet for it. if you could get the sump measurements for me that would be great. thanks again ![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
Last Edit: Mar 26, 2011 23:33:26 GMT by Deleted
@Deleted
Mar 26, 2011 23:40:05 GMT
Wth ref to this ![](http://memimage.cardomain.com/ride_images/3/640/4441/26599720043_large.jpg) Don't have any measurements i'm affraid but the c30se 24v engine from a carlton has a front drop sump as standard Its a big alloy affair that has braces at the rear that bolt to the gearbox aswell This is a side view (front at left) The middle was cut out for clearance when fitting it into a manta (about 1" cut from left side and sloping across top) ![](http://homepage.ntlworld.com/mantasport/mantasport/pics/shauns/c601otl%20(47).jpg) So that may not work for you. cheer's for that yeah front sump won't be easy to get round on the victor thanks for the info
petem
Mar 26, 2011 23:49:58 GMT
I'll measure the XJR lump if I get the chance. That'd be fun in something a fair bit lighter.
'99 Legnum VR-4 Type S Ralliart
'79 Escort 1300 Sport - long term project.
Beemer M52 (328, 528) engine is a straight six with a rear drop sump and lots of power (well lots to most people ![;)](//storage.proboards.com/forum/images/smiley/wink.png) )
benzine
@benzine
Mar 27, 2011 17:32:32 GMT
thats great stuff mate cheers for that. the volvo engine is actually a bit smaller than I had expected and may just work in there. I shall get the tape measure out in the morning and see just how much space i'm gonna have under the bonnet for it. if you could get the sump measurements for me that would be great. thanks again ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) I got an uncut sump out of my unit today and measured that (rather than my shallow sump) Sump width at widest point (rear of engine) - 400mm Deepest part of sump - 180mm Following 2 dimensions are if you are looking at the engine from the front of the car, they are how far the sump sticks out from the engine (i.e. extra width) Left hand of sump - 70mm Right hand of sump - 135mm Sump goes from shallow to deep after 390mm from front of engine Also forgot to add the engine leans to the left about 10 or 15 degress (at a guess) At the back of the sump, it's deeper at the right and shallower at the left
Last Edit: Mar 27, 2011 17:37:51 GMT by benzine
@Deleted
Mar 27, 2011 18:24:49 GMT
thats great stuff mate cheers for that. the volvo engine is actually a bit smaller than I had expected and may just work in there. I shall get the tape measure out in the morning and see just how much space i'm gonna have under the bonnet for it. if you could get the sump measurements for me that would be great. thanks again ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) I got an uncut sump out of my unit today and measured that (rather than my shallow sump) Sump width at widest point (rear of engine) - 400mm Deepest part of sump - 180mm Following 2 dimensions are if you are looking at the engine from the front of the car, they are how far the sump sticks out from the engine (i.e. extra width) Left hand of sump - 70mm Right hand of sump - 135mm Sump goes from shallow to deep after 390mm from front of engine Also forgot to add the engine leans to the left about 10 or 15 degress (at a guess) At the back of the sump, it's deeper at the right and shallower at the left cheer's for that its looking like that will be engine i go for i think . i will end up standing it upright as the victor has a small recess in the bulk head that just happens to be the right width for the engine to sit in nicely ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) measured up a RB26 Nissan lump today as i had one sat in a skyline i was working at the workshop but its quite a long old lump so everything so far is pointing to the Volvo lump ![8-)](//storage.proboards.com/forum/images/smiley/cool.png)
