Hi folks. My silver alfasud ti has a matt black paint finish around the rear number plate, well it used to but a lot of it has gone, weathered away over time. Can anyone tell me what spray paint to use on this and any tips on doing a better job than my normal cack handed efforts would be appreciated.
Also can I spray the bumpers or do anything else to get them back to original because they are more faded than my childhood memories. Cheers!!
the number plate surround shoudl be a simple squirt of some rattle can matt or satin black. Best bet would be to mask off the area to be painted, then give a light sand in 600 to key the surface and remove any flakes of old paint. Wipe down with a clean, damp cloth, then a clean dry one, then paint, using overlapping strokes, light coats at a time. You should find the finish more than adequate!
I take it the bumpers are plastic? If so, you can also buy rattle can plastic primer (plasticiser) then finish off with the afore mentioned satin black.
Last Edit: Jun 9, 2006 12:27:01 GMT by jettadeluxe
Cheers Jettadeluxe, yes the bumpers are plastic so even I should be ok doing this lol. Thanks for the info.
make sure you scrub bumpers up first as wax or silicon or whatever can hide in the grain and cause your new paint to lift. A good clean and preferably a degrease is what you need.
