I got offered a cheap twinky Sierra and couldn't resist, so the whOmega is for sale. I had suspected the headgasket had gone due to coolant lose but this has been fixed and I've just had the coolant check for exhaust gas and it fine. Still not sure if I'm doing the right thing as the omega is great fun!
I've owned the piece for 6 months and it's done me well, skids and drift well, plenty of lock, good steering and reasonable power too. I've just changed the oil, oil filter and replaced the coolant.
Tax August
MOT September
Spec:
Welded diff
Front -40mm lowering springs with a coil removed
Rear -40mm lowering springs
Vectra V6 solid flywheel and clutch conversion
Lock stops removed
Nardi steering wheel
Momo seat (fixed very close to steering wheel)
Stripped rear (rear seats if you want them)
Comes with:
Set of 15" alloys
Set of 16" alloys
Pair of 15" steels
It currently has legal tyres, the fronts being Bridgestone RE010.
Bad stuff:
Drivers side wing is dented
Drivers side rear turret has corrosion
Drivers side sill has a small hole
Luke harness is not included in sale (lap belt will be fitted)
Horn doesn't work
ABS and TC light on due to the rear wheel speed sensors being removed (they are included with the car)
Air bag light is on due aftermarket steering wheel
Photos:
Dented wing.......
Grotty turret.......
I'm located in Brixham, South Devon
Robin - 07920 103420 Talk to me! (or PM me ;D )
Tax August
MOT September
Spec:
Welded diff
Lock stops removed
Comes with:
Set of 15" alloys
Set of 16" alloys
Pair of 15" steels
Bad stuff:
Horn doesn't work
Photos:
Dented wing.......
