Alternative FWD struts?
Naturally I'd like to lower the front of my car & there aren't any known ready made bits about.
Sure I could chop/reset springs but the 30+ YR old dampers sealed into the original struts probably wouldn't like it & were probably on the soft side even when new.
The local (Australian) cheapy/self-serve wrecker is advertising a sale on struts & springs....
So I was wondering about the idea of swapping in the complete coil-over MacPherson strut from another car (with swapped top-mount), it's only one of the most common suspension set-ups around (except amongst 80-00's Hondas!).
Surely there must be plenty of options for a circa 920kg FWD car, & the lower knuckle just clamps around the bottom of the 50mm dia strut so different lower mountings could just be cut-off.
I'd hopefully also be able to get some open-able strut casings if I wanted to upgrade dampers, lower springs or weld on adjustable coil-overs later?
1979 Honda Accord Hatchback
The original springs were approx 190mm long loaded (250 unloaded but secured in strut asm), 145mm Outer dia. (not a lot of room to go wider), and struts 230mm from spring to lower end of strut ( to accommodate 155/70-13" tyre dia. originally.
I'm mostly looking at donor cars in the 10-20yr age group as being most readily available at the wreckers.
I have looked at whats there but chickened out of getting anything so far.
I liked the look of the struts on these Mazda-323-Astina as being fairly short for their low styling but they had sealed strut & the cars probably a good 100+ kg heavier so springs might sit higher?
A few Ford Capri Convertible about as well (also 323 based), but again struts appear sealed
Are Seat Ibiza struts openable as they appear? look possibly interesting.
www.auto-types.com/images/seat/Seat_Ibiza_3_a92.jpg [/img]
Was defeated removing some to look at due to VW 18mm head nuts/bolts (Japanese favor 17 or 19mm)
Peugeot 205?
Plenty of Daewoo but steering attachment & lower knuckle might be too had to remove.
Ford Ka there as well, smaller strut Dia.
Any other ideas, suggestions, comments, obvious or possible problems I'm overlooking ? ?
Rear are similar struts as well.
Peugeot 205?
