diff
Feb 14, 2011 23:00:28 GMT
Feb 14, 2011 23:26:27 GMT
Last Edit: Feb 14, 2011 23:27:02 GMT by DavidB
yeah might just be static belts with no space for the reel. Like the old KANGOL ones...
The bolt for the other end might be the seat bolt? Does the backrest have a bolt retaining it at the bottom?
the inertia part is mounted in the boot same as a manta ,will try and post some pictures tommoz for you as it explains it the best
diff
yeah might just be static belts with no space for the reel. Like the old KANGOL ones... The bolt for the other end might be the seat bolt? Does the backrest have a bolt retaining it at the bottom? Rear seat does not bolt in , retained on hooks .
diff
the inertia part is mounted in the boot same as a manta ,will try and post some pictures tommoz for you as it explains it the best That would be cool cheers , do the belts go through the shelf then?
It might not be of any help, but I'm breaking a Mk3 Cav this coming weeeknd. If you haven't already sourced some, do you want me to keep the rear belts for you?
If you're not too far away, I'd be happy to help fit them as well....
diff
Feb 15, 2011 10:22:52 GMT
It might not be of any help, but I'm breaking a Mk3 Cav this coming weeeknd. If you haven't already sourced some, do you want me to keep the rear belts for you? If you're not too far away, I'd be happy to help fit them as well.... Thanks Bruce , I will check the suitability of mk3 belts and let you know before the weekend . Thanks for the offer of help but I'm in Rochford Essex.
diff
Feb 16, 2011 12:02:12 GMT
the inertia part is mounted in the boot same as a manta ,will try and post some pictures tommoz for you as it explains it the best Any luck with that picture for me mate?
Feb 16, 2011 14:09:56 GMT
were the bolt comes through into the boot were the belt mech fits in rear inner arch were the belt pivots on rear shelf,you should able to find the bolt hole by feeling around this area on the rear post. were the belt anchors on the bottom off rear wheel arch sorry for the delay ,hope this helps mate
diff
Feb 16, 2011 15:58:09 GMT
Excellant , really appreciate your help . This is why this place is so good .
