Feb 13, 2011 12:07:00 GMT
well, the moped's been put on hold at the mo as ive no intention riding it in rubbish weather. my dear old mum asked me to find her a bike so she can go riding with the kids as well. quick search on ebay found me this, for the silly sum of £10 it was listed as both tyres flat but other than being dusty still seemed in good order. went and had a look and bought it there and then. i was disappointed because it still had the original raleigh whitewall tyres on, well cool but very very cracked and although they still worked it would only be after a ride or two they'd prob split totally (and I'm sure it'd be when my mums 5 miles from home) so another ebay search led me to hopkinsons cycles, bid on 2 x whitewall tyres, start bid of £5.99 for the pair and won them. result. total investment so far is £20 for a cool retro bike up and running. i intend to pinch another members idea of string/wire to clean the inside of the wheels. I think it came up pretty good after a wash and oil/grease where needed. only thing I cant figure is the gear lever on the handlebars, no matter if its in 1,2 or 3 the pedaling diesnt seem to get harder/easier??? ;D
lae
Feb 13, 2011 16:38:12 GMT
Very nice. My housemate bought one of these for £60 and spent another £20 on it "getting the brakes done" by Halfords (all they did was fit new inner cables and levers with the wrong cable pull so the brakes were worse than before... boy I was livid). £20 for a running bike seems like a bargain in comparison!
The problems with SA hub gears are with the shifter 99% of the time. Check that moving the shifter moves the cable at the rear, and play about with the adjuster so that when the shifter is in 'top', the cable is only slightly slack. If the cable doesn't move, or if this doesn't work, then oil everything, or replace the cable.
You can check that the hub itself works by unbolting the shifter cable from the hub at the rear, you'll be able to play with the indicator rod (the thin rod with the little chain that goes in and out through the rear axle). The indicator rod should be screwed all the way in, then backed off about one rotation. Then rotate the cranks very slowly whilst pulling the rod - when there's no tension it should be in top gear, pull it out a little and it should go into middle gear, and pull it out all the way and it should be in bottom gear. You have to stop pedalling to change gear, but they change gear better when coasting rather than at a standstill. If this doesn't work then I guess the hub needs a rebuild (very rare) but they are so cheap you might as well buy a new one, or put a singlespeed BMX wheel on the back.
Last Edit: Feb 13, 2011 16:40:32 GMT by lae
Currently: Mk1 Focus blandmobile
Formerly: 1969 MG Midget 1972 Avenger GT 1981 Datsun Cherry 1989 Corolla 1979 Mercedes W123 200D 1995 Ford Falcon 1996 Ford Telstar (bet you had to google that one)
Feb 15, 2011 18:45:07 GMT
thanks for the comprehensive reply, I'm wondering if I tried to change gear on whilst pedaling you know, hmmm, i'll give it another go 2moro before I start tinkering, thanks again
Feb 15, 2011 19:12:13 GMT
Cool lil shopper that.
Unscrew the cable at the toggle chain on the hub. Pedal it and it'll drop into third gear.
(in theory)
Then put the shifter into third and connect the cable up at the toggle chain again. Adjust so theres just a lil slack in the cable... Then try it out.
don't change gear while under load. Changing gear and then pedalling a little (not loaded) helps it go in to gear though.
Feb 15, 2011 19:38:42 GMT
thanks for the reply retro, will try n change gear 2moro and report back lol. yeah well chuffed really, a light sand on the chrome to get surface rust off, a good wash and two new tyres and its good to roll anywhere now
Jan 29, 2014 13:35:58 GMT
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Raleigh Hercules folding bikeretrolegends
@retrolegends
Club Retro Rides Member 94
Jan 29, 2014 13:44:19 GMT
Have a go yourself, I got two inner tubes for my folder for £5.99 inc postage off the bay of E
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Jan 29, 2014 13:46:59 GMT
I wouldn't even know how to put them in!
Jan 29, 2014 13:51:05 GMT
Maybe a pump up will do...!
Jan 29, 2014 17:06:32 GMT
It about as simple as can be, you don't even need tyre levers just a couple of big spoon handles will do, i'm sure there will be loads of how to videos on the net
awoo
Jan 29, 2014 18:04:59 GMT
they only need pumping up don't entertain changing the inner tubes they're holding air - absolutely no need to change them.
if you can get to brighton with it i can go over it for you - i do these bikes all the time.
otherwise take it to a small bike shop. anywhere but halfords
It can be tricky getting the wheels out of folding bikes like these. The semicircle rear mudguard might mean that the tyres got to be deflated before the wheel will come out, or go into the frame. Probably restricts tyre choice a bit. Probably only to 1.75 wide tyres. Maybe 2" if its quite a smooth tread. Not knobbly tyres that are easy to get for kids mtbs. I think thats a mid 80s bike. There will be a 3 digit number on the rear 3 speed hub, giving month and year. I think if its "new" enough it will have lock nuts on the cones on the front wheel axle. Older Raleighs had no locknuts. Had a weird system where the fork ends had a sort of keyhole shape, to hold the cones on the front axle. I always found them a right pain. As the forks had to be levered open a bit to accept the wheel, and tightening the wheel nuts might affect the adjustment of the wheel bearings. It looks to me like its got the original brake pads, that have alloy er backplates. Those pads might be leather faced. Or if they are all rubber, they will be old and hard. So I would recommend you to change them, as they will be not very good/ dangerous, as they wont grip the wheels very well, if at all. Best to get pads that are for those brakes. I have fitted V brake pads, that have a lot of special shaped washers, for adjustment. Those are common on a lot of bikes, very easy to get. To my Raleigh Traveller roadster bike. That has similar chrome plated brakes. The slots are a bit wider and the pads took ages to set up.
Love the folding bike! I bought my Hercules for a fiver from the local tip, spent a bit on it but now it's my favourite means of zipping to the shops.
1994 Rover Metro 1994 Peugeot 405 Estate 1991 Rover Metro Gti 16v 2001 Fiat Seicento Sporting 1999 Fiat Punto 1.2 1994 Peugeot 106 Xnd (x3) 1991 Westfield 7 2004 Landrover 110 SW 2003 Seat Ibiza 1.9Tdi Sport 1959 Ford 107e Prefect 1992 Suzuki Vitara 2008 Skoda Fabia
