Hello! These wheels are Exacton 13" by 5.5" - not D1's etc as these have a bigger slope at the end nearest the lip on each spoke thingy and came std with the Ginetta many moons ago, a set of 5 and are 4" PCD
I have all the centre caps and nuts (missing four and the others will need restoration or replacement)
One alloy has slight damage to lip, not an issue to use but would need to be filled in to be perfect. Alloys are in etch primer as per photo!
£150 collected only
£150 collected only
