My housemates MX5's front drivers side caliper is sticking. He's not hugely mechanically minded but knows what end of a spanner does what, however doesn't really fancy attempting a brake refurb himself. What can he do to try and free it off in the short term until we can have a look at it back in bath? Any tips? Can't really afford to have someone look at it because he's spent all his money on coilovers ;D
dungbug
'Ooligan!
I've had a sticky caliper, if he isn't able to use the spanners then there's little he'll be able to do. I removed the pads, pressed the pedal to draw the caliper piston out. The piston was a bit gammy so gave it a quick once over with some very fine wet & dry, quick squirt of brake cleaner, pushed it back in. Pressed the pedal and pushed the piston back a few times & it didn't stick again.
mk5tom
Hi, just thought I'd mention that theres a chance it could just be the flexible brake hose collapsing internally rather than a sticking piston. To test if it's this pump the brakes a few times (with the wheel in the air) then open up the bleed nipple a bit and see if the wheel then turns freely, if it does chances are its just the brake hose. I wasted money on a new caliper and other parts on my accord before I checked this! Doh! A new hose was only a couple of quid!
change the brake hose.....(s)
if not good clean of caliper with autoglym alloy wheel cleaner
pump pistons and clean and roberts yer faithers brutha
2001 HONDA CT110 (NOT RCV)
He's bitten the bullet and dismantled it. Piston was fooked so new caliper, pads and tools ordered. Wish him luck please!
