Jan 22, 2011 21:26:53 GMT
hi, i'm going to see a mk1 gti tomorrow and the seller says that the oil pressure light comes on..i've heard it could be a sender issue?
Could someone post a pic showing the location of the pressue sender on the car? Just so i know where to look.. Thanks in advance!
mrj
Jan 22, 2011 21:54:52 GMT
it should have two switches, one at the rear of the cylinder head and the other near the oilfilter ....
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Jan 22, 2011 22:06:39 GMT
it should have two switches, one at the rear of the cylinder head and the other near the oilfilter .... Thanks:)would it be above the filter on the housing?i just want to be sure where to check before i make the trek to see the car.. cheers
RobinJI
Jan 22, 2011 22:23:00 GMT
yeah, main pump pressure sensor is on the oil filter housing just above the filter its self, below the coolant pipe going into the front of the head. Then there's a secondary sensor on the head.
Do you know when the light's coming on? If it's only when warm and at low revs, then it's probably not a sensor or electrical issue.
Jan 22, 2011 22:52:14 GMT
yeah, main pump pressure sensor is on the oil filter housing just above the filter its self, below the coolant pipe going into the front of the head. Then there's a secondary sensor on the head. Do you know when the light's coming on? If it's only when warm and at low revs, then it's probably not a sensor or electrical issue. Hi thanks very much! the seller said that when she topped up the oil (to the max level on the dipstick) there was a 'pop' when she started the car, and some oil was squirting out. The dash light was on.and engine was cold I'm thinking its either a blown diaphram in the sender unit leaking oil, or possibly the filter seal has blown?
