Left over from my Metro/Mini days
1 new turbo fuel pump £40
1 used turbo fuel pump £20
1 turbo fuel pressure regulator £25
1 turbo boost control ECU and bleed valve £10
1 T3 oil drain elbow (alloy part that bolts to the turbo) £10
1 T3 exhaust elbow £20
1 Turbo to plenum silicone hose - £5
1 1" slicone hose elbow used to fit dumpvalve - £5
1 T3 standard waste gate actuator £10
1 T3 turbo dismantled with damaged compressor wheel for spares (what do you need?) £10
1 Metro turbo standard oil cooler with hoses £20
1 Oil cooler approx 6" square fin area £15
Also
New old stock track rod ends (pair) to fit metro - £10
New old stock kuckle joints (pair) to fit metro - £10
EBC 'black' brake pads to fit metro - £5
Standard brakepads to fit metro - £5
Used hydrogas suspension units - £5 each
Set of standard wheels/tyres (band em!) - free to collect
also a big box of other misc spares - free to collect
Pair of brake calipers to fit metro turbo (rare vented disc type) probably need recon - £20
Mini bonnet - £10
Mini radiator - £10
Roofrack sutible for mini or whatever!- £20
full 998cc a+ engines, 12g940 cylinder heads, pre A+ block and cranks gearbox/clutch casings/parts plus many other a-series parts avalible so please ask.
all prices are ono, and do not include postage
Everything is located in Sudbury, Suffolk. If you are serious please PM or email me at slaterspeed@gmail.com as I'm pretty bad at checking my forsale threads!
Also
Mini bonnet - £10
Mini radiator - £10
