bstardchild
Club RR Member Number: 71
Putting together a little shopping list but thought before I start trawling egay/demon tweaks etc I'll ask on here as I prefer to recycle from an enviromental perspective Alloy Fuel Tank (Baffled or foam filled) In and out pref with a level sensor - Capacity 30-40 Litres5 Inch large Tacho - suitable for conventional coil and a 6 pot lumpWater temp gauge - analogue and electrical sender type Oil pressure gauge - analogue and electrical sender typeVoltmeter gauge - analogue Fuel Gauge - analoge Stand alone fuse box - 8 fuses min Toggle switches Hole punch Die thing for 1mm Steel sheetNot much really But like I said I'd rather recycle ;D
I have some gauges available,and a fuse box I think....
bstardchild
Jan 10, 2011 22:38:35 GMT
I have some gauges available,and a fuse box I think.... What Gauges? I've managed to tick two off the list and I'm still on the look out for a fuse box so interested
bstardchild
Jan 10, 2011 22:39:04 GMT
I've sent an enquiry off - thanks for that link
Jan 10, 2011 22:51:27 GMT
Oil pressure and fuel gauges I got,and a 12 way fuse box if I can remember where I put it lol
bstardchild
Jan 10, 2011 23:45:00 GMT
Oil pressure and fuel gauges I got,and a 12 way fuse box if I can remember where I put it lol Best news I've had today - when you've found em all let me know
Jan 11, 2011 19:37:32 GMT
if you get stuck, PM me about;
Water temp gauge - analogue and electrical sender type Oil pressure gauge - analogue and electrical sender type Voltmeter gauge - analogue Fuel Gauge - analoge Stand alone fuse box - 8 fuses min
i have all of these (mostly black dial / white pointer Smiths) and a compact 8 blade fuse box (used but only a couple of years old)
bstardchild
Jan 25, 2011 12:31:27 GMT
Nearly there now ;D
Jan 28, 2011 13:10:57 GMT
I've got the fuse box on the right of this pic. It takes 10 fuses, both lids have a crack in them (bloody postman!), but seal fine. Looking for £5 plus post (£3). Can get a better pic if you like.
