Mar 13, 2012 20:19:22 GMT
I would have that back it was, and looks like it still is, a great car Since buying the car from you, it's had the following done: 1. Proper service, including new fuel, oil and air filters, fresh oil and coolant. 2. Pair of new rear tyres. 3. New battery (not cheap!). 4. Sony MP3 headunit and 6x9 rear speakers. 5. Exhaust re-hung as it was squeaking. 6. Replacement M Sport side trims. I don't think the mileage has increased by more than 5k. Matt rarely drives it hard. The only time it gets a spanking is when I take it out for a spin. ;D The only thing that spoils that car is the steering. Due to the wide tyres it tramlines too much and feels too sticky around the centre. I like it but I prefer my MR2.
1985 Mercedes W123 230E - 5 speed manual & 2011 BMW F11 520d Touring - 8 speed automatic.
Mar 25, 2012 18:13:21 GMT
Apr 12, 2012 12:19:08 GMT
Legs eleven! (bingo term apparently) Still going strong.
zircon
Apr 12, 2012 15:28:32 GMT
Looks good mate - you need to find some locking wheel nut covers by the looks of it.....
Apr 12, 2012 20:03:43 GMT
Looks good mate - you need to find some locking wheel nut covers by the looks of it..... Well spotted! I've got two, two have dropped off.
The W123 has needed a little attention. The exhaust manifold No 4 cylinder gasket has been blowing for a while and recently it got worse. I removed the manifold, which involved undoing 8 nuts / bolts. 6 nuts were 12mm, one was 13mm and one was 7/16th imperial. Fortunately, all nuts and bolts came off without drama. The cylinder head around the No 4 exhaust port was a bit sooty. Old gaskets and new. I got the new gaskets from Mercedes. Job done. I replaced one nut as a precaution. After heavy rain, water pools in the rear offside footwell. It drains down from the front footwell under the carpets. The front screen rubber seal must be letting water through or the lip around the screen has corroded. Probably the latter. I applied more sealant around the edge of the seal but that hasn't helped. I'm going to drill a small drain hole in the front floorpan, so that any water that drips in will drain straight out. Simple but effective. In the meantime the MR2 is still going strong.
Apr 15, 2012 15:53:49 GMT
i had that in my dayvan fella i used capt tolleys creeping crack cure great stuff got mine of ebay two doses did the job still got half a bottle left
Apr 15, 2012 16:07:24 GMT
Hope it's not the common tin worm infection... Check the underseal for 'crunch' noises. Where the frame rail meets the firewall, in the front foot well. Common spot on 3rd series W123s Or bonnet hinge pockets. Hope it's not that! Fingers crossed! That generation of MR2 is growing to me fast. Cheers, Jan
Speedle
Apr 16, 2012 13:47:41 GMT
just read this thread start to finish (don't tell my boss! ) Awesome rides dude and my god what a list of cars! Nice to see you ended on a Rev 3 SW20, have one myself and love it to bits! Your repairs across all the cars are awesome! really impressive!
Apr 17, 2012 12:12:05 GMT
I had that in my dayvan fella I used capt tolleys creeping crack cure great stuff got mine of ebay two doses did the job still got half a bottle left Do you have any more info on this wondrous product? I'll get some if you reckon it would solve the problem.
Apr 17, 2012 12:19:17 GMT
Hope it's not the common tin worm infection... Check the underseal for 'crunch' noises. Where the frame rail meets the firewall, in the front foot well. Common spot on 3rd series W123s Or bonnet hinge pockets. Hope it's not that! Fingers crossed! That generation of MR2 is growing to me fast. Cheers, Jan Jan, When I investigated the problem first time round I traced the leak to the bottom offside corner of the windscreen. I suspect there's a bit of rot in the lip around the screen. The bulkhead and hinge pockets are all solid. I recently scraped off loose paint from the hinge pockets and coated the metal with primer. I like the MR2. I've had five prior to this one and know them well. Trouble is that I rarely drive it, I love the Merc too much to leave it at home.
Apr 17, 2012 12:20:26 GMT
just read this thread start to finish (don't tell my boss! ) Awesome rides dude and my god what a list of cars! Nice to see you ended on a Rev 3 SW20, have one myself and love it to bits! Your repairs across all the cars are awesome! really impressive! Thanks mate. The blue Rev 3 is my sixth MR2 in 10 years. Cheap good fun just about sums them up. Any more info on yours?
Apr 17, 2012 14:41:37 GMT
Last Edit: Apr 17, 2012 14:42:36 GMT by stretch
Apr 21, 2012 14:08:38 GMT
Stretch, thank you for your message. I have inspected the front screen rubber and can't see where the water is coming in from. Everything is nice and tight and full of sealant. We've had some heavy rain this week and a small amount of water has dribbled in. The water drains to the rear offside footwell and resides there until I mop it up. Fortunately, following the repairs I carried out last year, the floorpan is not suffering any further damage. To allow the water to drain out before it reaches the rear footwell I've drilled a hole in the front footwell. I've coated the hole with Waxoil to prevent any onset of corrosion. With the exhaust manifold gaskets replaced I am getting closer to finding the source of a blow, which can only be heard when the engine (thus the exhaust system) is cold. I suspect the blow is coming from a crack in the downpipe flexi-pipe. I've tried squirting soapy water on the downpipe hoping I would see bubbles where the crack is, but the water just evaporates. Any ideas how I can locate the crack? There is no soot build up or any obvious defects to be seen. The front brake pad warning light has been coming on recently - yellow light on the dash. I know my pads are good so the problem must be with one of the sensors or wires. I could not be bothered to investigate further, which would involve jacking the car up and taking wheels off, so for now all I've done is unplug the sensor wiring within the engine bay. The plugs are located along the tops of the inner wings. I will sort this out properly next time I have to take the front wheels off.
Apr 22, 2012 10:11:57 GMT
no worries fella but that good stuff might be able to seal it with that could be cheap fix good luck
The MR2 is now sold. As far as the company car is concerned, I have narrowed my choice down to two cars: 1. Mercedes C220CDi AMG Sport Coupe: 2. Mercedes E220CDi SE Executive: The Coupe looks better but is smaller inside and less comfortable. The E-Class has more space and is more luxurious but looks a bit common and that shape will be facelifted in approx 12 months. I will have to keep this car for 3 years and I don't want to be driving an obsolete model after just one year. As matters stand I'm hoping to get the Coupe.
Right guys, time for a well overdue update on the W123. A few weeks ago, whilst visiting family, I spotted a Nissan Micra being taken through a bizarre 9 point turn manoeuvre which resulted in the Micra reversing into the front of my Merc: Fortunately, the only damaged caused was a broken indicator lens. Matey paid up on the spot and I bought a replacement part from ECP the following day. The Merc's service was due. I bought all my parts from ECP. Service parts for W123s are quite cheap so I went the extra mile and bought the best quality parts. Which fitted perfectly. Since my engine breather vent mods there have been no running issues, no further oil leaks and the air filter housing is clean where the vent passes through. Easy access to the sump plug. After 30 minutes every last dribble of the old oil drained out. Before and after. Fitting new plugs has cured the cold start hesitation that affected the car since I bought it! With the fresh oil, air filter and plugs the engine is running like a dream.
The exhaust blow was getting more annoying. I spent a lot of time trying to trace the location of the blow. I knew it was coming from the downpipes, somewhere towards the top, but not within the joint between the manifold and the downpipes. I had the downpipes replaced a couple of years ago, so evidently something had split (rather than corroded). Not wishing to have them replaced again, I wrapped the entire length of the downpipes with high temp exhaust wrap, usually used to reduce under bonnet temperatures. It wasn't an easy job (due to access) but I got there in the end. My first journey with the wrap fitted resulted in a lot of smoke and whiffs of melting plastic. I was a bit worried but after a few days of driving around the smells and smoke stopped and the downpipes stopped leaking. The wrap must has melted and sealed the crack. Result!
