Dec 15, 2010 23:08:10 GMT
Early Harrison L5 Gap Bed lathe, will swing approx 16" in gap and I think 9" over saddle (will check if needed) it's around 2' between centres, comes with 3 and 4 jaw chucks. currently fitted with 3ph motor but could easily be changed to a single phase. It's not in it's first flush of youth but i've used it for a few years making bushes, spacers etc and even some reasonably precision bits with care. More history on these can be found at www.lathes.co.uk/harrison/page2.htmlI'm Near Hinckley Leic's and can load onto your transport, guess it's about 350Kg. Price £85, viewing welcomed and can be seen under power. Cheers Brian
Last Edit: Dec 16, 2010 15:59:55 GMT by Good Scrap
Dec 15, 2010 23:13:24 GMT
Why must all these things be so far away from me!!! (((((((((((((((
purplevanman
Way too orangey for crows
Dec 15, 2010 23:34:33 GMT
bargain Tempting but as I already have 1 lathe this is a bit far
Does this come with any spindles/centres for the tail stock? Any cutting bits? If so then I think you may well have a buyer Been wanting to get a lathe down at the unit for some time. This looks like the right kind of thing. PM on its way....
stefan
If it isn't broken fix it till it is
I will take it if not alreadsy gone
Last Edit: Dec 16, 2010 8:58:32 GMT by stefan
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
10mpg
Club RR Member Number: 204
Yep So will I.
no question
Seth
Dec 16, 2010 10:30:56 GMT
Does this come with any spindles/centres for the tail stock? Any cutting bits? Cheap enough to get those kind of bits new Bruce.
Dec 16, 2010 11:19:33 GMT
I will take it if not alreadsy gone Yep So will I. no question Sorry guys, looks like it may well be heading for Area 52 on Monday if things go to plan and a very nice RR guy is able to collect it for me (thanks Diabolu ;D ) If it all falls through then it looks like it's not going to struggle to find another home. Brian, you have another PM
10mpg
Dec 16, 2010 12:45:42 GMT
You lucky bu gger Bruce, that's the cheapest lathe worth having i've seen in ages..
Better of buying new tip tools, than mucking about with old tool steel ones, gets you going again in seconds if (when) you smash one rather than having to strip down the whole job regrind the tool and srart all over again... so much easier in the long run, get a left and right handed turning tool a parting off tool and a boring bar, and a Dti & verniers should enable you to do most simple jobs...
Will cost more than the lathe probably but that's because they lathe is crazy cheap not that the tools are expensive (if you see what i mean)
Last Edit: Dec 16, 2010 12:55:22 GMT by 10mpg
DutyFreeSaviour
Dec 16, 2010 12:51:32 GMT
why do I NEVER see these things in time!!!
Can I ask something then - will this mean some lathe tuition from those in the know when this is in at A52?
Really need to learn how to use one of these properly........
Dec 16, 2010 15:59:33 GMT
Provisionally on it's way to Area 52, if it falls through (which i don't think it will) then i'll let those who expressed an interest know.
I priced it with what i am happy to pass it on for, call it crazy cheap - but fair for it's condition, it's taking up floor space and all i wanted was a bit more than scrap value. oh, and i need to make way for a Bridgeport mill :-)
Dec 16, 2010 19:31:09 GMT
ooooooo looking forward to getting my teeth back into machining, not done it since my apprenticeship 9 years ago
pbottomley
If at first you don't succeed, then skydiving isnt for you
Dec 16, 2010 19:50:16 GMT
I am just around the corner and thought about this, alas the bedroom doesn't have 3 phase and I find lathes uncomfortable to sleep on LOL
purplevanman
Dec 16, 2010 23:41:00 GMT
ooooooo looking forward to getting my teeth back into machining, not done it since my apprenticeship 9 years ago you are always welcome at my place m8, lathe and mill (ask Bruce) to play with
NICE ONE ! I'm gonna need access to your mill for doing my hybrid gearbox
DutyFreeSaviour
oooh Grunty - you 'holiday destination' you........ HAHA -I'm in the queue I think. How much you charge for lessons then?
Dec 17, 2010 10:20:10 GMT
Once we get the new lathe set-up at the unit and make sure it's all working properly, Ross & I could pop over to Alan's for some lessons/refresher (last time I used a proper lathe was 1988!!) then we can do lessons for people down at the unit....as well as making cool stuff!
Sound like a plan? Saves Alan's barn workshop being over run with A52 regulars...although his Mum makes a cracking cuppa and a demon bacon sarnie ;D ;D
Dec 17, 2010 11:52:12 GMT
Area52 wheel adaptor production line lol.
Matt
