Hi, has anybody got a mk1 astra recaro about that they could measure the mounting points of. I have some to go into my cortina but they are at the trimmers and I want to get the mounts made up.
What I need is the distance from between the front and rear mounts (part that point downwards with 3 bolt holes in) , and distance between left and right mounts.
I did measure them up before the went to the trimmers but can't find the piece of paper. (from memory I think it was about 40cm front to back and 42cm left to right but cant be sure).
Thanks in advance for your help.
