fad
Oct 14, 2010 15:30:06 GMT
... or know of a thread in which someone has achieved this? I am just embarking on another project, and want to fit a Ford Cologne lump under the bonnet.
The exact details of the amitions are in my readers rides thread, but I would like to see other projects along the same vien.
... and, no, I don't want to go V8, K series, Vtech (sorry, Ztech!), twin cam, steam powered, Mk2 reciprocating dingle hopper or any other engine LOL! I've been asked so many times "why not use this engine? That engine?" and while I am aware other engines are higher revving, offer better power to weight, will do my washing up for me and walk the dog if I ask it, I want to use the V6, thank you please! ;D
Oct 14, 2010 15:34:09 GMT
Yeah, I know the feeling good on you for sticking to a plan. And yeah, the cologne will fit.. it's a pretty tried and tested formula too - a couple of years back I pulled an early 80's custom MM (fur, jack kit, wolfies, sidepipes...) out of a barn that had a 2.8 in it. In fact, the ford engine was about the only reuseable part....
fad
Oct 14, 2010 15:49:44 GMT
Excellent! You didn't happen to notice how it was cooled did you? I want mine to be a street sleeper, so have challenges like keeping stock looking wheels with the different PCD of the innevitable disc brakes, if the engine will even fit un the engine bay without an obscene amount of butchery etc. I think the type 9 gearbox will more or less fit without any hassle at least!
Oct 14, 2010 15:59:52 GMT
Cut the bulkhead and shift the motor back as far as it'll go. A lad I know bought a Minor saloon with an essex v6 mounted without cutting the bulkhead and the handling was dangerous. Not only did it understeer and snap oversteer, when he upgraded the front brakes it'd do stoppies. Not good.
Matt
Oct 14, 2010 16:49:29 GMT
But IIRC the Cologne is lighter than the Essex. Light enough? I don't know.
Mk1 Polo discs are a quite easy conversion from what I've heard, and since they are 4/100, they can be made to fit the original PCD with just a slight enlarging of the holes... If I remember correctly, it has been a while ago since I last heard about it...
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
Oct 14, 2010 16:58:56 GMT
They're both iron block, iron heads so can't be that much different.
Matt
fad
Oct 14, 2010 17:24:45 GMT
I want to absolutely avoid cutting the bulkhead, doing so constitutes chassis / monocoque modification and comes with a nice BIVA test...
Last Edit: Oct 14, 2010 17:37:20 GMT by fad
Oct 14, 2010 17:39:22 GMT
2.3 cortina rad or V6 mk2 granny rad is fairly compact and will cool the 2.8 no bother, Scorpio rads are a bit lower but a lot wider, i guess you need to fit the engine and see how much room is left, shouldn't be hard to find a rad that will fit.
fad
Oct 14, 2010 18:04:22 GMT
Cool cheers for that matey!
Oct 14, 2010 18:18:02 GMT
They're both iron block, iron heads so can't be that much different. Matt IIRC the Essex are heavier than a Ford V8 Smallblock...
Oct 14, 2010 18:23:20 GMT
If youre deteremined to go V6, what about sourcing a later 24V Scorpio motor..
Gotta be lighter as its got alooominum in it, and may need less cooling.
Koos
Oct 14, 2010 18:30:28 GMT
If you're not wanting to cut the bulkhead i'd bin the Cologne V6 idea altogether. It really was a deathtrap, great for rolling burnouts though. Stick a 1.8 Rover VVC engine in they're more powerful than the boat anchor, and weigh curse word all as they're all ally.
Matt
Oct 14, 2010 18:51:40 GMT
Oh oh.... youve done it now! :-)
If weight is a big problem then how about a Rover KV6?
I know its not a Ford boat anchor, but it is a shed load lighter, and cheap to buy.
Koos
Oct 14, 2010 19:13:32 GMT
A lightweight V6 would be perfect as they're shorter so you can push them back further. How much do Alfa V6's weigh?
Matt
Oct 14, 2010 19:22:54 GMT
A fair amount. It's an old engine design with an iron block. You also then get into gearbox games as RWD Alfas use transaxles.
Edit - Omega? Mercedes?
Oct 14, 2010 20:04:55 GMT
Back before they all swapped Fiat twincams in, the V4 was the engine of choice.
Oct 14, 2010 20:47:05 GMT
AFAIK Alfa V6's are all ally?
Matt
Copey
Oct 14, 2010 21:19:02 GMT
no idea of fitting, but if you do fit a cologne, DON'T fit the 2.8i out of a capri, the ports are siamesed so tuning potential is very low, 2.9 12v engine out of a scorpio is the way to go, same block but better heads and better tuning potential, the 24v 2.9 is a good engine too, again cologne based, but being a quad cam its pretty wide, struggle to get into a minor possibly?
Oct 14, 2010 21:20:48 GMT
Width isn't as much as an issue with Minors, its getting the motor sat far enough back so that its not hanging infront of the front wheels.
Matt
Oct 14, 2010 22:14:01 GMT
24v still manages to almost fill a Cortina engine bay despite being "short"
