Aug 25, 2010 12:26:25 GMT
My car is going into a friends body shop next week for some welding which requires the engine to be removed.... I like the I dea of fitting my 73 saab 99 with PAS. However.... Fitting 900 power steering to a 99 is tricky due to the locatoin of the pump. Some one sugested EPAS. This is becoming quite popular Using parts from a corsa... However... Does anybody know any modern cars that use an electro hydraulic system instead... My plan is to fit a 900 PAS Rack and use an electronic pump seems somewhat simpler than cutting up the steering column?
Back in an e30!
Aug 25, 2010 12:54:34 GMT
SW20 MR2's use electric power steering, but its a massively complicated system with speed sensitive ECU's etc...
Corsa option seems the best.
'95 Toyota MR2 Turbo '72 Toyota Celica TA22 '74 Mercedes 350 SL '68 Mercedes W108 280SE '03 Renault Clio 172
Aug 25, 2010 12:59:51 GMT
Thank you dubmaster, this is the question that I wanted to ask! But instead retro fitting EPAS or a Corsa system into a Nova. I know it seems silly but because of health reasons it would make it easier for my wife to drive.
Anyone done this? Or can paste a link for more info?
(Sorry, I don't want to hitch your thread)
pirate
Aug 25, 2010 13:03:29 GMT
try the search button, theres been a couple good threads on it iirc my punto has dual power steering, i think thats electronicals might be another car you can use for bits. with the city button on its one finger steering! handy for your mrs
persistant retro offender. 04 laguna load lugger alfa 159 lusso beast 82 austin allegro 82 mg metro
Aug 25, 2010 13:30:21 GMT
the corsa power steering column is a common fit on minis - particulalr those fitted with other usually more heavier engines.
Aug 25, 2010 13:45:02 GMT
Have you asked around/searched on saabscene? Someone's bound to have done it before and Saab scene is the most mind-bogglingly technical of the saab forums.
IIRC mounting a 900 rack on the 99 will be a significant PITA as well. It certainly won't just bolt on.
Last Edit: Aug 25, 2010 13:48:17 GMT by tonedepear
Aug 25, 2010 13:57:51 GMT
Quick look on eBay shows - Astra MK4 (98-04), Zafira, Citroen Saxo, Peugeot 106 and others have electric PAS Pumps. In fact I think our Skoda Fabia 1.4 diesel has one !
Paul H
Aug 25, 2010 13:59:29 GMT
MantaKev has a rather excellent write up on how he fitted Corsa B power steering to his awesomely badical Cossie Turbo Manta in his build thread HERE ;D That car seriously rocks
Aug 25, 2010 14:01:09 GMT
Corsa is quite a common conversion for old Fords as well.
Aug 25, 2010 14:19:15 GMT
MantaKev has a rather excellent write up on how he fitted Corsa B power steering to his awesomely badical Cossie Turbo Manta in his build thread HERE ;D That car seriously rocks I smell a wiki entry!
matty2300
Red ones go faster!
Aug 25, 2010 14:50:55 GMT
2002 Saab 93 - Daily 1972 Vauxhall Firenza Sport SL - in storage 1978 Vauxhall Magnum - PROJECT 1993 Vauxhall Cavalier 2.0 GLS - DEAD 1994 Vauxhall Astra 1.4 LS - DEAD 1999 Saab 93 2.0 SE - DEAD 1999 Mercedes W202/C200 - DEAD
gib
Aug 25, 2010 15:10:17 GMT
Unfortunately the it fits on this so it will fit on that is not so straight forward esp using power columns. I have a an 82 99 with a 16VT and when i stripped it out, checked and designed some mounts for a 900 rack as they are not to difficult to make. They key issue is the angle of the rack to steering column. I was concerned about this especialy considring the ratio so discounted a powered column as the torque and mounts would be a head ache. There is a guy in scotland who is currently making a stage car that is going down this route check uksaabs.co.uk. I am still looking at a seperate electric pump single speed with external switch ( no speed signal) Have a look on my page here as i have a load of pictures showing parts of the build and there should be some with the 900 rack in place. s380.photobucket.com/home/gengis-khan/recentuploads?page=1
Aug 25, 2010 15:48:00 GMT
My old Saxo VTR (1997 model) had an electric PAS pump and quite a simple-looking setup - certainly no speed sensitive stuff or electronics, just the leccy pump run through a beefy relay and heavy cable so it was turning whenever the engine was running and a normal-looking PS rack and plumbing.
Last Edit: Aug 25, 2010 15:54:50 GMT by dave21478
Aug 25, 2010 16:20:56 GMT
HE HE! I love this Forum.... So many answers so quickly! I have checked some of the saab forum and found a few threads regarding the Corsa conversion. However I think I would like to try a Hydraulic set up... Just to clarify.. Is the Saxo 106 a Hydraulic system then?? This is my next port of call then!
Back in an e30!
Aug 25, 2010 16:23:05 GMT
try the search button, theres been a couple good threads on it iirc my punto has dual power steering, I think thats electronicals might be another car you can use for bits. with the city button on its one finger steering! handy for your mrs What engine is in your Saab 90? Swap you for a mountain Bike?
Back in an e30!
Aug 25, 2010 17:00:37 GMT
Here's the thread I did started about it a while back.... retrorides.proboards.com/index.cgi?board=general&action=display&thread=75882I've since found someone who does the trigger modules for less money; and they're working on a more trick setup at present. My module has a potentiometer giving a range from off to full assistance. The guys I found afterwards are doing one that you can remap with a laptop; so it could work like mine, or give a narrower range with better fine tuning ability. Joe
Aug 25, 2010 17:08:50 GMT
Cheers Joe, Have already read your thread before posting this. A guy on uksaabs posted a link! I really want to try and make a hydraulic system up... But this will be the next option if its a no go.
Back in an e30!
pirate
Aug 25, 2010 20:45:32 GMT
dubmaster i just edited my sig, saab sold last week, was a 2.0 8v.
is there a reason why the fiat system doesnt get used? I'm sure most from 99 had it
