hi I'm needing some nova wheels for my new sr project these sort i know they must be rare i am in telford shropshire i would consider any other vauxhall 1980s wheels if i cant find these ones many thanks davy
Aug 22, 2010 15:24:11 GMT
this probably wont help, they look like the ones fitted to the later 1.4 sr's and sri models from the early ninties, is there a chance they might be on some of the corsa's too as it was a change over time between models I think?
I owned a silver 1.3 SR with GTE kit and aftermarket three spokes wheels back in the day (1995).
goos luck with the project
Aug 24, 2010 14:36:20 GMT
Last Edit: Aug 24, 2010 14:38:20 GMT by joem83
Aug 24, 2010 19:41:36 GMT
hi I'm needing some nova wheels for my new sr project these sort I know they must be rare I am in telford shropshire I would consider any other vauxhall 1980s wheels if I cant find these ones many thanks davy i may be able to lay my hands on a of couple of these wheels if i can get the present owner to part with them
1982 opel ascona 1.8 sr/e hatchback (mk2 cavalier) 1 of only 2 known to exist in the uk 1982 mk2 cavalier saloon 1.3 base model
robg2
Aug 29, 2010 13:07:11 GMT
5 spoke steels come in at least 4 styles (I've got some of each):
13 x 5J ET49 14 x 5J ET49 14 x 5.5J ET49 13 x ? x much lower offset - RWD?
13s came on early SRs and 14 x 5J came on the early 90's SRi (Mk2). Corsas didn't have them; but they could have been on some obscure Mk2 Astras like SXi etc.
Before you ask, the only full set I've got are about to be sold on the Cavalier they're fitted to - so I can't help you out I'm afraid.
robg2
Aug 29, 2010 13:09:19 GMT
hi I'm needing some nova wheels for my new sr project these sort I know they must be rare I am in telford shropshire I would consider any other vauxhall 1980s wheels if I cant find these ones many thanks davy i may be able to lay my hands on a of couple of these wheels if I can get the present owner to part with them I've got a couple of 13s I don't want - if the ones you mentioned are also 13"s then there's a chance of putting a set of 4 together.
Aug 29, 2010 20:16:12 GMT
cheers that would be cool of you
