on a hb sl90 were is the switch for the window wipers ??
were is the indicator flasher relay located ??
my indicators horn or flash / full beam isnt working the stalk seams fine and seams to be wire up correctly (with original wireing) is there any were obvious i should look (i check the fuses they seamed ok)
what is the wee black switch at the side off the dash in between the dash and the a pillar it seams to turn the dash lights off ?
and where would i get a new battery for it ? is there a deisel battery thats a similar shape and size that i could use?
