Seeing as I'm a lazy and have done next to nothing to this project since I bought it three years ago, it's time to shift my Turbo Mini project.
1986 Mini City base. Excellent shell painted in red with white roof and Cooper mirrors. Cooper seats. Minilights, Yokos, KYB adjustable shocks, big bore exhaust, modified tank with return pipe, Metro Turbo fuel pump...
When I bought it it had badly fitted Sportspack arches which I removed but luckily the front arches hadn't been cut. The hinges have also been removed for the bonnet as the previous owner intended to fit pins. Finishing the holes from the arches and sorting the bonnet mountings are the only bodywork jobs I am aware of that need doing. If you want to go back to hinges the pin mount brackets that have been welded in will need cutting out, otherwise I have a spare bonnet with pin-holes already cut in.
Most of the other work needed on the car is electrical and this includes either connecting or replacing the dash made by the previous owner. The car was hotwired to run when I bought it but has not been run since.
Car is located in the Willenhall area of Coventry, a couple of minutes from the Toll Bar End A45/A46 junction.
Please PM me for further info or to view.
