Carlos
Jun 24, 2010 19:52:39 GMT
Bought this off here last year but haven't really used it as much as I thought I would so it's time to give it a new home. It's a 1/2" 18v cordless impact gun, model CTU3850. Comes with charger and a dud battery (possibly due to lack of use?). When I try and charge the battery the red light on the charger just flashes which indicates a battery fault. Worked fine before that - never failed to undo anything. Perfect if you've got something that uses the same battery already or you can just buy a new one. Apparently they can be repaired too - t'internet suggests that 'flashing' it may wake it up, or you can buy the bits to rebuild it from Maplin. Happy to post if required. Cheers
Carl -------------------------------- 1992 Peugeot 205 GTi 2.0 16v 2004 Volvo V50 T5 --------------------------------
nutter81
I joined facebook so i could talk to the missus
Jun 24, 2010 19:55:50 GMT
how about £60 posted
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Battery sensor most likely at fault. pence to fix. I work with these guns all say long (as in for Snap On) its unlikely to be totally stuffed unless its got wet.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
Carlos
£60 is a bit low nutter, the chargers alone go for £45 + post on the Bay. Definitely hasn't got wet stinkwheel. How easy is it to fix, as if I can I will so I can make a bit more money for the V8 fund
stinkwheel
get a multi meter and check the negative and sideways battery terminals. They 'should' read about 11 - 12.6 K Ohms. Or thereabouts. If its dead short or open circuit then its definitely the sensor on a flying lead to the middle of the battery thats gone. pence to replace from RS components or similar (part number 198-927) if thats OK then you have dead cells in the battery, thats bad, we used to replace them but ther strain of new cells tends to kill the old ones dead then. So its not worth bothering. Hope that helps mate.
I'm sure mine sometimes flashes red for a while when I put the battery in, I've never worried about it, just leave it to charge, stops after a while...
The guns are awesone, I wouldn't be without mine now, lives in the car!
stinkwheel
hardcore, yours does that because the voltage in the battery is too low, if it charges after a while then the charger has lobbed enough volts in for it to then charge properly.
Oh, lol - best ignore me then (apart from the bit about these being awesome!) ;D at £75 I'm almost tempted to buy another..
Carlos
Jun 25, 2010 16:11:04 GMT
Bear with me guys...
The reading is 9.73kohms - do you reckon that's too low and is worth replacing the sensor, or is it just dead cells causing the issue?
Jun 25, 2010 16:27:45 GMT
I'll take it how do you want the cash?
stinkwheel
Its a hard one to call that mate, the reading is a bit low, but it 'should' charge at that, so I'm thinking dead cells, if you put a multi meter on after its sat for 5 mins after its had a charge what voltage do you get?
Carlos
Jun 26, 2010 10:07:33 GMT
Before the charge it reads 1.29v. After an hours charge it reads 1.33v.
stinkwheel
Jun 26, 2010 18:53:11 GMT
I would pronounce that battery dead mate, Obviously if you or anyone else should need one i have no idea how you might go about getting one, i mean for instance you wouldnt PM me <wink wink>
Carlos
Jun 27, 2010 11:10:24 GMT
Righto, thanks for your input stinkwheel!
So, as suspected the battery is a dud, but if you search really really hard you should be able to pick up a spare if you need one. Usedandabused was the first person toput dibs on it, so if you still want it it's yours. Will drop you a PM.
Last Edit: Jun 27, 2010 11:10:46 GMT by Carlos
Jun 27, 2010 14:15:44 GMT
Sold.
Sure enough all but two cells were dead,
RS do heavy duty ones for £4.10 each!!.
60 odd quid plus the hassle of re-building means that's a no-no.
Just as well I know a certain gadgie with one for sale cheep!!
Cheers chap's.............
Guns up and running and the first jobs done,
Full set of EBC discs/pads and eight front control arms on my Passat all done in a morning......
Why didn't I buy one of these ten year ago!!
Thanks to all involved definitely one of my better buys...........
stinkwheel
Nice One:)
They are very useful, in fact, i think they are essential.
Carlos
Nice one mate, glad someone is getting some use out of it!
