Up for sale as sick of tripping over them.
A petrol cap, will try to get pics up later, basically it is a tri lobed stainless steel cap, with key in excellent condition, designed by the look of it to fit on the outside of a car, not under a flap so suspect Mk1 fiesta? Anglia? Early cortina?
How does £10 sound?
Capri and Cortina (MK3) dashes, there is probably enough bits here to more or less make one of each, the cortina dash needs a bit of TLC but is all there, the gauge pod, glovebox lid and fascia are all in used but usable condition. £10 the lot.
Capri dash is better, dash pod good, couple of fascias including I believe a brooklands? wood dash fascia. Enough bits to make a nice fascia and dash pod. Apparently the brooklands bit is the valuable bit at circa £30, how does £30 the lot sound?
I'll do the lot at £50 posted and throw in any other old ford bits I have kicking around.
How does £10 sound?
