strange brake problemretrowagen1234
@GUEST
hmmmm, did it blow any fluid out the top of the cylinder? could be blocked and only allowing the fluid to come up and out?
nope no fluid leaks any where at all. ive had masters go on a few cars but they never start working perfectly after again. seems very strange.
Could also be a vacuum problem with the servo. Make sure you check for air leaks too. Servos can corrode underneath (and therefore out of site) along the seam that holds the front half to the back half and as a result air can escape.
Had this a couple of weeks ago on a mini. It's the master cyl seals letting fluid past the seal between the 2 circuits when used/pumped. Then when you leave it for a bit, it self bleeds back past the seals to where it should be. It'll get worse very quickly.
'83 GTM Coupe. 4A-GE Powered '00 GTM Libra Auto. Ick. '71 Detomaso Pantera. Current Resto '89 GMC Safari Tow/Kip bus '05 SAAB 9-3 Daily '71 Siva Moonbug. Not even contemplating resto yet.
kv77
Could also be a vacuum problem with the servo. Make sure you check for air leaks too. Servos can corrode underneath (and therefore out of site) along the seam that holds the front half to the back half and as a result air can escape. Can't see how this would make the pedal go to the floor. Wouldn't a leaking servo cause the engine to run like curse word also? definitely sounds like internal leakage in the MC imho How about a rebuild? Or are ford parts so cheap you shouldn't be bothered about that?
Last Edit: May 21, 2010 9:17:32 GMT by kv77
<a href="http://retrorides.proboards.com/index.cgi?board=readersrides&action=display&thread=81096&page=1"> My 1975 Mazda 616</a>
May 21, 2010 10:05:36 GMT
I thought id be able to get one for cheap but don't seem to be common anymore so rather expensive. ill have a look I breakers today and replace seals in one of them.
100% its the master, cheers for the help chaps
Last Edit: May 21, 2010 10:06:59 GMT by damageandy
May 21, 2010 11:48:07 GMT
Normally leaking m/c seals will show up as small trace air bubbles in the clear reservoir as you depress the pedal.
