-Scott-
I am easily satisfied with the very best.
I drive a 998 mini
how ever..
In my shed sits a spare engine.
Its a 1098 out of my Allegro... its done 35,000 miles since 1979.
My question for you lovely people, what can be done to it?
I know from experience it has a fair bit of poke for the size of it, but as is the way, i want more POWWWWERRRR (haha)
But not the the extreams of having to rebuild it every 3000 miles.
Now I don't have a lot of money, but I can save up for certain things if I have to.
I already have a bigger carb (weber 32 down draught) and a decent exhuast.
What are you thoughts?
Would putting a different head on it help out, and if so, which one?
(I cant afford turbos or chargers, and i don't want to get it re-bored)
Thanks guys
Scott
Keep calm and carry on
Would putting a different head on it help out, and if so, which one? A Honda CBR600 head would really liven it up ;D Fits the 1098, I'm not sure if the more common BMW K1100 head does. ...I don't really have any useful suggestions I'm afraid. But something for you to think about ;D
-Scott-
how much work is envolved with this?
Russ
For the best power per pound, fit a cylinder head of a 1275 metro, HIF44 carb and inlet manifold off a MG metro with K&N filter. Had that setup on my 998 metro along with a Maniflow lcb manifold and exhaust, really livened it up and would do 80mph all day long. It you want to go a step further fit a camshaft from a MG metro and a distributor with a modifed advance curve, should give you a good bit more torque as well then.
-Scott-
sounds like a good plan nice and simple, but fairly effective with the sounds of it
Russ
Yep certainly is effective. It's the mainly the cylinder head that restricts the small bore engines (998, 1098) as they have the closed type chambers and small valves, so fitting the larg bore head will liven it up a fair bit. Forgot to say though, if you do want to fit a MG metro camshaft, you would have to recess the exhaust valves into the head about 1-2mm, as the exhaust valves of the large bore head overlap the small bores of the 1098 and will hit the block if not done. It's an easy job for an engineering company to do though.
-Scott-
Id stick with the head and carb, don't want to be pulling the insides to bits haha.
would a weber run it as well as the SU? Got one in the garage awaiting a service, its off an old 1600 cortina (32 dfm down draught)
Russ
Not sure tbh, never had experience running a weber on an A series engine, have read that people have had good results with them though. The standard 1.5" SU would still perform well on that setup along as you fit it to a decent inlet manifold and use a K&N filter, a HIF44 (1.75") SU just gives more top end power and my 998 engine was more responsive with one fitted.
-Scott-
Thanks Russ, thats been a massive help. Ill ask on the mini forum about the Weber, but i can tell you now, in going to do that.
Just need to find a head now haha
Nausssssssssssssssssssssssssssssssssssssssssssss.......
;D
Team Blitz Ford Capri parts worldwide: Restoration, Road, or Race. Used, Repro, and NOS, ranging from scabby to perfect. Itching your Capri jones since 1979! Buy, sell, trade. www.teamblitz.com blitz@teamblitz.com
slammed 66
www.gtturbo.org
Alot of people have successfuly turbocharged 998 a series engines
86 Renault 5 GT Turbo 89 Renault extra 91 Skyline GTR 98 Mini 1275 mpi 99 Autech Rider www.gtturbo.org
Prud
Before you kick off, you really should have a long hard read through David Vizards book - How to Hot Rod Your A Series. If you don't have it, buy it. It's worth every single penny. And then some.
I never knew the 1275cc head would fit a "small block" Mini. I always thought they were about an inch or so longer. But comparison of head gaskets would answer that one anyway. As far as I know the only difference between the 1098 and 998 was a long-throw crank. So the 998 will rev harder but the 1098 would be torquier.
The biggest secret with my 1380A+ are the valves. They're standard Mini Metro Turbo A+ valves. The ports are huge, the combustion chambers are cut back as far as possible, the pistons are really high compression. But the valves are standard and supposedly "tiny". But that little bit of restriction makes for monster air speeds into the chamber. Think of it like putting your thumb over the end of the garden hose. Big air speed is how I can get a big cam to work at 1500rpm, not 4000rpm like it's supposed to. It does lose out at the top end (she runs out of puff about 6500rpm), but it makes frying tyres easy. It also pushes the Morrie to 220kph (so far).
If I was going to do up a 1098 on the cheap, I'd start by putting a respectably big cam in the 1098 and porting the head. Try to make the ports large (they are horrible standard) without lowering the floor too much. Aim for a shallow angle between port and valve. Cut down the valve guides (a bit, not remove them completely) too. De-shrouding the valves is a good idea, but you'll lose compression unless you shave the head/drop in high compression pistons to compensate. While you have the grinder out, dowell the head and intake so you can port-match them. But don't do that to the exhaust. So at this point, all you've shelled out for a Dremel (or similar) and a cam kit.
Now, before you do anything else, drop the head back on it and take it for a drive. Try the combo of small valves, lots of porting and larger cam for yourself. If you like it, keep it. If it's too restrictive, then take the head off it and go up in the valve size. It'll only cost you one head gasket more that way - and if it all goes according to plan, you'll end up with a really driveable car. I know this advice flies in the face of everything everyone has ever said about getting horsepower out of cars, but this is a road car, not a high-rpm screamer race car.
As for the Webber, you've got it, use it. My personal preference would be for a single 1.5 inch SU. My 1380 runs as sweet as a nut on a HIF44 1.75 inch SU.
But aside from all that, remember that at the end of the day - it'd be cheaper and more horsepower laden if you started out with a 1275...
I'd try and find a 12G295 head, as used on the MG1100 and Cooper 998.(I have heard that the A-plus head fron the 998 Metro and later Minis was modelled on this- might be worth investigating.) They do turn up quite frequently if you know where to look. I'd use the stock carb on a better inlet manifold (the Oselli Torquemaster was the one to use 'back in the day', but one from an MG Metro is almost as good) and a decent LCB exhaust. Be warned though, the 1098 don't like to rev (6000 as an ABSOLUTE max).
