130k on the clock
indian red metallic paint in generally good condition, the driver rear quater has been resprayed and is not perfect
no major rust. there are some scabs under the front arch trims which have been sanded back and painted over with hammerite
sills are solid. driver side one has a small repair near the rear arch
new cambelt and water pump fitted at 120k
vw2 calipers fitted with ferrodo pads and vented/drilled discs, all less than a month old
new front driver side bearing fitted same time as the brakes
oil changed at the begining of feb 10
uprated headlight loom and phillips xenon style headlights (so very bright)
poloace chip
4 branch and full decat stainless exhuast
roof bars
tinted headlights
clear indicators
gt arch-kit
sunroof
golf steels with trim rings
rear mudflaps
snazzy cam cover
front door pods with 5" mb quart speakers fitted
1 off turned alloy gearknob
seats are in perfect condition
taxed and mot'd till april 2010
spotlamp grille and h/lamp protectors not included
after a swap for a skoda pick-up or mk2 vw caddy pick-up
would also consider a civic 1.5 or any other small engined car
poloace chip
roof bars
tinted headlights
clear indicators
gt arch-kit
sunroof
rear mudflaps
snazzy cam cover
