stuey
ram thruster 4000
Feb 14, 2010 16:05:14 GMT
i need help... and some batteries! I have had some starting issues with my chevy g20 camper and I have replaced the alternator but the batteries are still not charging so I have decided to replace them. (nothing more irritating getting caught short in a 3 ton 17 foot long van that wont start) Sadly I picked the wrong version for this as its a 6.2 dieseasel and has twin batteries (hooked up as a 12v system from the factory) Any hoo -back ground aside I cant seem to find what the original spec of the batteries should be so I can get the replacements (friend works at the local lucas parts place so a discount can be had) any ideas where I can get some info- a lowrider packed with batteries in thanks!
1987 fiat 126-nearly actually done! 1972 beetle - lawn art 2003 z4 daily-new wheels a comin! 2008 R56 Mini cooper "mental Mickey"
stuey
ram thruster 4000
any one?
I cant help with the spec, but with an engine that size, I wuld just buy the largest batteries (physical size and current apacity) that will fit in the battery mounts, that I could reasonably afford.
any ideas where I can get some info a battery shop. as Davelotsofnumbers said, i'd measure the physical size and see whats the biggest Amp battery you can get hold of. Alternatively the guys a US Automotive might be worth a call, I'm sure they would be able to help.
stuey
ram thruster 4000
Feb 15, 2010 10:11:49 GMT
thanks guys - didnt know if you had to buy batteries relevant to you alternator amperage? etc etc- I'm not big on charging systems and wanted to make sure I got the best match for my new atlernator.
Feb 15, 2010 10:20:05 GMT
Feb 15, 2010 10:20:51 GMT
No you'll be okay - provided your batteries can cold crank what the starter requires, the charging circuit should be able to sort out the alternator amperage and charge rate on its own. Bigger = Better I think in this case!
stuey
ram thruster 4000
Feb 15, 2010 10:53:07 GMT
cool chips guys its appreciated! have this in thanks-
