Feb 14, 2010 13:58:06 GMT
Afternoon, Trying to remove my brake caliber so I can replace the front disc's. One bolt has started to round. It is 13mm, I have tried to hammer on a 12mm socket with no luck. So what sized imperial socket falls between 13mm and 12mm?
If there is a size I'll try that first, before trying to weld another bolt onto the rounded bolt head. As I have not got great access all the way round to weld.
deejay
WELSH DRAGGIN'
Feb 14, 2010 14:03:49 GMT
Get yourself a 6 point socket instead of 12 point they grip better and are less likely to round it off matey, also try a half inch socket as half inch = 12.7 mm
HTH, Dean.
Feb 14, 2010 14:05:43 GMT
WHS ^ Much better grip with a hex socket than a bi hex,should do the job !
Feb 14, 2010 14:29:37 GMT
Use Stilson wrenches. I've never known a nut to be non-defeated by mine. These are plumbers ones, you can get more mechanical orientated ones. The harder you turn, the tighter the grip gets.
Last Edit: Feb 14, 2010 15:00:09 GMT by DavidB
Feb 14, 2010 14:40:01 GMT
irwin bolt grippers will have it off
or try a hammer and chisel to bash it anticlockwise , once youve nudged it a quarter turn pliers will undo it
rounded 13mm boltBenzBoy
@benzboy
Club Retro Rides Member 7
Feb 14, 2010 17:13:03 GMT
irwin bolt grippers will have it off Another vote for Irwin bolt removers. Screw-Fix do a set for about a tenner I think.
Last Edit: Feb 14, 2010 17:13:37 GMT by BenzBoy
Feb 14, 2010 17:54:33 GMT
@benzboy
Feb 14, 2010 18:43:23 GMT
That's them. Must've been twenty quid at Screwfix, it was a while ago. Worth it though! Stilsons are great if you have a lot of room around the bolt head to get them on, and a space to give the handle some decent leverage. Either will get the job done!
Feb 14, 2010 18:50:31 GMT
well worth having the irwins in the tool box...they fit anywhere a slightly big socket would
not failed me yet
Feb 15, 2010 18:52:05 GMT
the irwins are the best bit of kit ive got to get me out the curse word lol
thrud
Feb 15, 2010 19:04:01 GMT
id also opt for a decent hex socket & as a last resort a 1/2 inch or if push comes to shove 12mm 12 point & a BF hammer to apply it
1976 cavalier coupe , 1985 manta gte hatch , daily 2001 rover 75 cdti
Feb 15, 2010 20:13:09 GMT
last time I had that problem I ground a hexagon head a size smaller on the bolt, it wasnt prefect, but it shifted it
Feb 15, 2010 20:15:41 GMT
got it off thanks guys
a proper hex socket rather than a bi hex socket did it in conjunction with a long bar.
Feb 15, 2010 20:30:20 GMT
Irwin bits are amazing - I've got some locals are welcome to borrow.
Anglia68
Powered By Boredom.
Feb 15, 2010 21:34:17 GMT
I use an old trick of wrapping a short length of grit paper,60 or 80 grit or whatever comes to hand but coarser the better,around the bolt head and then tapping the socket over it to make a nice tight fit. It also works with mole grips even when the grips on their own just chew up the head.
