Tom's (awesome) Farina thread in the RR section made me think - i wonder what other unusual gassers there are out there From a little searchy I found the following: ;D Anyone else seen anything else unusual?
"Mechanical Power Subduing Animal Speed" (Robert Trevithick, 1808)
'72 BMW 2000 Touring '99 TT 180 (mrs) '72 BMW 2500
Seth
Unusual Gassersjettadeluxe
@GUEST
Brian, you need to make this render a reality!
joda
joda
oops posted same post twice ;D
Last Edit: Feb 4, 2010 11:41:32 GMT by joda
Last Edit: Feb 4, 2010 12:35:32 GMT by bigkris
OK, n00bish gasser question - is the Moon tank out front for purposes of weight distribution?
OK, n00bish gasser question - is the Moon tank out front for purposes of weight distribution? Not really. When it's up front the lines can be much shorter, plus you get an inertial "ram" effect when accelerating hard. On a quick enough drag car this effect can actually be quite significant, helping the fuel get to the fuel pump much better. Also, gassers tend to run mechanical injection pumps which I believe require a positive pressure head of fuel (ie. gravity fed). Does anyone know if that's correct?
Davenger
It's only metal
Club RR Member Number: 140
Unusual GassersDavenger
@dminifreak
Club Retro Rides Member 140
love the thread I had one very similar when I first signed up but noone replied with any results lol. loving the bond bug lol ;D This is still around It lives in Ipswich, it's owned by Sniper on here
Taunus: Kadett:
Nice work, peeps! BigKris - what a quality selection of snaps you have I think you're more worthy of starting this thread than I with that sort of a collection!
g40jon
another daft question...... whats the reason for the raised ride height? looks cool, but surely i cant be good for stability?
The front end's raised to allow the fitment of a beam axle from a truck, which is lighter than an independent front setup - doesn't do anything for handling, but they're only going to be going in a straight line anyway. I think that's right. Anyone?
The beam axle's only there to assist with the stance. The front end is raised to increase weight transfer on launch.
Raised ride height at the rear also allowed fitment of bigger tyres with less cutting of the body. There were some rudimentary theories going around at the time I believe which suggested that there was greater weight transfer to the rear at that height, thus improving 60ft time or something. At the end of the day it's not actually the optimum set-up, but that was what they thought would work at the time.
Kris, some awesome stuff you've found there What is this? It looks kind of Hillman Minx, but kind of not. I like it. I want it.
chaps all the pictures i posted were stolen from gassermadness.com/^ go on....you know you want too
