5x Compomotive MO 17" 7J wheels with centre caps. You will need spigot rings to suit your bore, but they should go on quite a few cars. I believe them to be ET40 but the stamping is quite faint so its hard to make out. These are 4x100.
4 are powdercoated dark grey as shown below and are fitted with Toyo Proxes size 205/40/17, very good all round.
Two fronts are 7mm and 6.5mm (NSF slightly more wear). Rear ones are 5.5mm and 5.5mm.
The 5th is the OE colour which is a bronze colour and comes with a Yokohama same size, 205/40/17 with reasonable tread (excellent spare, no need to reduce speed after a puncture/wheel change!).
I would like offers around £375 for these given that there are 5 of them and 4 have good tires.
Thanks,
Karl
Based in Wigan but get around a bit (oo err) with work so could possibly meet up/deliver.
07809400 eight eight three
Thanks,
Karl
