Potter
'E who dares wins,eh Rodders??!
Jan 29, 2010 21:07:14 GMT
Bit of a strange one. Apparently they bolt straight up to Series Land Rovers and give you locking diffs and massively improved ground clearance.
Wheels as well if you have them please.
More cars than sense or money!🙄
Potter
Know it's a bit of a long shot but bump anyway!
Gray
Silence isnt golden!!!
They are the holy grail! It is the portal axles you are after? expect frightening prices
Steve
Making progress in small, easy to handle chunks of awesome
Agreed! I was after a pair for my 109" but it seems they are rare in this country and anything under 1k aint worth having! Have you been in contact with Jez at House of Flying Spanners? I belive he has a contact that imports these axles(tap House of Flying Spanners into google, they have a website with contact details)
Steve
Potter
Are the non portal ones not worth looking at Gray? Cheers for the linky Steve,Checking it out. Did you manage to get a pair?
Gray
Are the non portal ones not worth looking at Gray? Cheers for the linky Steve,Checking it out. Did you manage to get a pair? Its the portal ones you want if your going for clearance (cos of the way they convert power from the axle to the wheel) Definately the ones to have
Violet Vivid
Reports of my demise were somewhat exaggerated
Violet, purple-loving Landy obsessed Purple-haired CyberPunk Almost model & occasional word wrangler regarding Landies xXxIf she can't decide on what kind of genitalia she likes to play with you're better off without her. Move on... play with Land-Rovers.
Potter
Cheers Gray,Vee. Vee Thanks for that.Maybe not everyone's definition of bolt-on is the same!
Emailed Jez at House of Spanners as well. Will post when he replys in case it's any help.
Steve
As for me getting a pair, once i found out the prices of them I sorta went off the idea! If you want an example of a 109 with portals, one of Jez's mates has a maroon station wagon running a 4.6 megasquirted v8 and volvo axles, he posts on LR4x4.com under the name of FridgeFreezer if you want to have a word with him :-)
Steve
I've got some Laplander axles! The only issue here is that the so-called Laplander was the L3314 and the subsequent C202, not the C303! (I'll get me coat) If you're interested in these, they'll be going cheap fairly soon. Apparently, they are Dana based/copies and the brakes are from the Series parts bin. Deffinately stronger than series axles, but probably not the ones you had in mind. They are a better size match for a Landy than ones from a 303 though. Have a pic of my laplander c202 for your trouble....
Potter
Thanks again Steve.Looks like I'm going to be repeating your actions mate!
Joe are they portal axles?
I'm affraid not mate! They'd be a millionsquillion pounds if they were!
Cheers, Joe.
Potter
Oh well. Thanks anyway Joe. Got no reply from Jez @ House of Spanners,by the way.
