Hi Guys, Looking to fit a specific type of external door lock/handle for my Rochdale. Problem is I have an idea what I want, I just can't find where to buy any! I basically just want a key lock with a small finger pull attached. Similar to this thing (without the rectangular backing section) - The only car I can find which had something similar fitted was the original Lotus Elite - Anyone know of any others cars fitted with them? or, just a place that sells them new
Dez
Club RR Member Number: 34
any vw camper van, or beetle. used on the decklid/tailgates. cheap as chips from gsf and the like.
any vw camper van, or beetle. used on the decklid/tailgates. cheap as chips from gsf and the like. Good call, thanks, that has the rectangular plate to it though, was hoping to find one that fits flush to the panel any other ideas?
Aha, I need something very similar for th Bond tailgate! Off to check GSF now. Thanks Dez!
any vw camper van, or beetle. used on the decklid/tailgates. cheap as chips from gsf and the like. Good call, thanks, that has the rectangular plate to it though, was hoping to find one that fits flush to the panel any other ideas? The black plate is a rubber weather seal and can be removed. Will that help?
Good call, thanks, that has the rectangular plate to it though, was hoping to find one that fits flush to the panel any other ideas? The black plate is a rubber weather seal and can be removed. Will that help? Well, not really. If you look at the lock on the Lotus, it is ideal. It is a round push button mounted directly into the bodywork - there is no rectangular mounting section. I basically want something that doe not stick out of the body, aside from the little finger pull.
Ah ha! Just been through my usual kit car people, but I cant find anything. Maybe use some real lotus ones?
Yep, my 1st thought too, unfortunately, they seem to be as rare as the car itself. 1 2nd hand sold on eBay recently for £123 it is spot on though -
Ooh pricey! Nice though! Just had a thought, take a look at late 60s early 70s Mgb boot handles.
I know it's a long shot, but Commer PA/PB van?
fredje8v
96 Daihatsu Atrai
If i remember correctly, a Opel kadett C (chevette) Caravan has that sort of lock on the tailgate. Should be easy enough to find
